FSword7 Posted December 3, 2023 Share Posted December 3, 2023 Folks, I tried to get some from whtech site with wget command. wget can't download some files due to 404 errors in /Cassettes/rawWAVfiles folder. Does anyone able get all wav files through wget command? Someone told me that wget is not effective for mirroring because it does not support delete option. He recommends rsync with --delete option is the most effective way for mirroring. Rsync replaces old ftp protocol. I tried to rsync some from whtech but it did not response. Does someone at whtech plan to implement rsync access on whtech site? Thanks, Tim Quote Link to comment Share on other sites More sharing options...
gferluga Posted December 3, 2023 Share Posted December 3, 2023 Wget works for me: localhost:~# wget "https://ftp.whtech.com/Cassettes/rawWAVfiles/3D-LABY%20(2).w av" --2023-12-03 18:35:17-- https://ftp.whtech.com/Cassettes/rawWAVfiles/3D-LABY (2).wav Resolving ftp.whtech.com (ftp.whtech.com)... 148.135.75.22 Connecting to ftp.whtech.com (ftp.whtech.com)|148.135.75.22|:443... connected. HTTP request sent, awaiting response... 200 OK Length: 3986220 (3.8M) [audio/x-wav] Saving to: '3D-LABY (2).wav' 3D-LABY (2).wav 100%[==================>] 3.80M 768KB/s in 5.7s 2023-12-03 18:35:23 (680 KB/s) - '3D-LABY (2).wav' saved [3986220/3986220] localhost:~# 1 Quote Link to comment Share on other sites More sharing options...
FSword7 Posted December 3, 2023 Author Share Posted December 3, 2023 Ok, I executed it again, but I did not see 404 errors anymore. My wget command was: wget -m -np https://ftp.whtech.com/Cassettes/ Quote Link to comment Share on other sites More sharing options...
FSword7 Posted December 4, 2023 Author Share Posted December 4, 2023 Well, when I tried execute 'wget -m -R "index.htm*" -nv https://ftp.whtech.com/', I can only see some 404 errors but got all 60 GB stuff. http://ftp.whtech.com/Cassettes/rawWAVfiles/2171¯D.wav: 2023-12-03 18:23:55 ERROR 404: Not Found. 2023-12-03 18:23:55 URL:http://ftp.whtech.com/Cassettes/rawWAVfiles/2171%c2%afD. wav [955180/955180] -> "ftp.whtech.com/Cassettes/rawWAVfiles/2171¯D.wav" [1] http://ftp.whtech.com/Cassettes/rawWAVfiles/2180¯D.wav: 2023-12-03 18:23:55 ERROR 404: Not Found. 2023-12-03 18:23:55 URL:http://ftp.whtech.com/Cassettes/rawWAVfiles/2180%c2%afD. wav [5539628/5539628] -> "ftp.whtech.com/Cassettes/rawWAVfiles/2180¯D.wav" [1] It showed 404 errors but successfully downloaded them. I think that filenames contain Unicode characters. I checked downloaded files and see them. NTFS and ext4 supports Unicode characters in filenames. I recommend rsync over wget so that whtech need to enable rsync access. With wget, I have to make a backup and download entire site each time because wget do not support delete option. Rsync do support delete option so that you can update it each time to save file data transfers a lot and much faster. Tim 1 Quote Link to comment Share on other sites More sharing options...
