Shift838 Posted December 5, 2023 Share Posted December 5, 2023 (edited) I'm working on a new card and I want to implement a Real Time Clock that would be compatible with the below RTC's. This would be for on the clock functions, no printer buffers or anyting. CorComp Triple-Tech Fred Kaal's IDE Date/Time clock calls, set, etc Maybe MBX Clock as well. I have been reading the DSR Specifications for the TI-99 and since I have never done this before I think I may need some tutoring. I know Fred put's his DSR's on a SRAM but when the battery goes out you need to reload, not a big deal, but that would mean I would have to work out a program to write DSR to the SRAM as well. I was thinking of putting it on a EPROM. Any takers to help me out? Edited December 5, 2023 by Shift838 2 1 Quote Link to comment Share on other sites More sharing options...
+FarmerPotato Posted December 5, 2023 Share Posted December 5, 2023 If you have SRAM in the DSR, your program only has to enable the card then copy it to >4000. I can imagine a bit to enable writing else protect. If you want to write to Flash in-system, it's a 6-byte command stream to unlock it. The catch is: you have to maintain CE during the bytes. I think you can just tie CE low and gate your chip enable to OE. Quote Link to comment Share on other sites More sharing options...
apersson850 Posted December 5, 2023 Share Posted December 5, 2023 I made a real time clock back in the days when there was none commercially available. But I was mainly interested in reading it from Pascal programs, so the DSR I actually did was to allow interrupt handling on the clock. I wrote a DSR which could display the clock on the screen all the time when the p-system was running. Access to the clock itself was by a unit I included i the *SYSTEM.LIBRARY in the p-system, so that didn't require any DSR at all. I have the DSR in SRAM too, so it must be loaded again when necessary. 1 1 Quote Link to comment Share on other sites More sharing options...
+FALCOR4 Posted December 5, 2023 Share Posted December 5, 2023 8 hours ago, FarmerPotato said: If you have SRAM in the DSR, your program only has to enable the card then copy it to >4000. I can imagine a bit to enable writing else protect. If you want to write to Flash in-system, it's a 6-byte command stream to unlock it. The catch is: you have to maintain CE during the bytes. I think you can just tie CE low and gate your chip enable to OE. If using SRAM that has the possibility of being corrupted (ex: low battery voltage) then don't forget a switch to disable the DSR space or you may risk a constant cycle of lockups upon powerup. 2 1 Quote Link to comment Share on other sites More sharing options...
speccery Posted December 5, 2023 Share Posted December 5, 2023 I don't think this is what you're looking for, but anyway, for what it's worth: I've been contemplating with the idea of making a simple FlashGROM type cartridge, with only a microcontroller implementing GROM capability and a separate regular SRAM chip connected to the cartridge port (probably also with latch to support paging of SRAM if larger than 8K, and a little glue logic to choose whether writes from TMS9900 go to SRAM or the address latch). I've advanced my grommy2 project lately, and this idea of MCU+SRAM came to mind. Looking at documentation on TI Tech Pages, it appears that GROMs can contain power up routines. Such a routine could copy initialisation data from GROM space to SRAM, making the SRAM work like ROM. Although I've been thinking about this idea in the context of a very simple cartridge, there's nothings stopping using the same idea to init a DSR RAM from GROM. A single GPL instruction MOVE >1000,G@>8000,@>4000 would copy 4K of code from GROM address >8000 to the DSR RAM (provided the DSR memory was enabled with the right CRU settings). 2 Quote Link to comment Share on other sites More sharing options...
Shift838 Posted December 5, 2023 Author Share Posted December 5, 2023 I should clarify, this is not a cartridge board but an expansion board for the PEB. Quote Link to comment Share on other sites More sharing options...
Gary from OPA Posted December 5, 2023 Share Posted December 5, 2023 17 hours ago, Shift838 said: Any takers to help me out? if you have questions, or need help, let me know, i am more then willing to walk you thru some of tough parts if you get stuck. 1 Quote Link to comment Share on other sites More sharing options...
