+jeremiahjt Posted December 15, 2023 Share Posted December 15, 2023 One of the wires came loose from the Wi-Fi module when I was adding a new hard drive. Do both both wires lay on top of each other, or is there one on either side of the screw hole? I placed the loose one on top of the other one. I am picking up some Wi-Fi networks, but not all of them. I thought it might be a 2.4/5g thing, but I am just guessing. Any help would be greatly appreciated. On the plus side, my new 1 terabyte hard drive is working and I got Atari 50 moved over. Once I get connected to the VCS Store, I should finally be able to update it. Along with updating Avian Knights and downloading my two new games and the two games I uninstalled trying to make room for the Atari 50 update. Quote Link to comment Share on other sites More sharing options...
joeatari1 Posted December 15, 2023 Share Posted December 15, 2023 Here is a pic of the connectors. The ones that are being used are the #1 and #2 pads. This is where your wires go. Quote Link to comment Share on other sites More sharing options...
+jeremiahjt Posted December 15, 2023 Author Share Posted December 15, 2023 Okay, that makes sense. There is no way I could have seen those markings though. Those are some tiny markings. Thank you. 1 Quote Link to comment Share on other sites More sharing options...
+jeremiahjt Posted December 15, 2023 Author Share Posted December 15, 2023 Well I managed to pull the other wire off too. No big deal I thought, Ant1 will go to pad 1 and Ant2 will go to pad 2. Well both of the wires are marked Ant2. Great. I figured maybe it does not even matter. Well now my Bluetooth is not working. Time to switch the wires I guess. Quote Link to comment Share on other sites More sharing options...
joeatari1 Posted December 16, 2023 Share Posted December 16, 2023 The wire position shouldn't matter. Just make sure they are connected and it should work fine. Quote Link to comment Share on other sites More sharing options...
+jeremiahjt Posted December 16, 2023 Author Share Posted December 16, 2023 I finally got them on. I did not realize that the wires actually snap onto the pads with miniscule shaped connectors. Thank you for the help. 1 Quote Link to comment Share on other sites More sharing options...
