alfchk Posted December 16, 2023 Share Posted December 16, 2023 Hi I search a replacement for D2 diode in 3do FZ1 Its "DED5P4JZE2-D", i donc find any Doc for this. And on 3do schematic Doc sometime it IS called thrusty diode, sometime its thyristor diode. I am sure this one IS defective because I have Switch with other 3do unit and it work perfectly with a New one. So i need compatible component. Any help IS welcome. Thanks by advance Quote Link to comment Share on other sites More sharing options...
Taijigamer Posted December 19, 2023 Share Posted December 19, 2023 This is the modern equivalent you need https://www.digikey.com/en/products/detail/littelfuse-inc/S4008DS2RP/409640 I compiled a list of components which act as modern equivalents for some of the PSU components which are now end of life. I haven’t included the electrolytic capacitors as they can be purchased via console5. I do recommend replacing C35 and C36 as standard on FZ-1. FZ-1_PSU_Component_List.numbers 1 1 Quote Link to comment Share on other sites More sharing options...
alfchk Posted December 20, 2023 Author Share Posted December 20, 2023 Big thanks to you 1 Quote Link to comment Share on other sites More sharing options...
