Tenorman Posted December 18, 2023 Share Posted December 18, 2023 Hello All, Has anyone here successfully burned a 4 MB ROM to 4 x 1MB 8-bit EPROMs and got it working with one of the four chip PCBs? I am trying to make extra copies of a couple games to use with Jaglink (Gamedrive and Jaglink are not compatible). I got the 4 x 8-bit boards mainly because I can write the EPROMs without adapters or doing anything special with the programmer that I have. I have not had any problems with 4 x 512KB EPROMs and 2 MB games. Things I have tried: -AT 27C080 EPROMs -ST 27C801 EPROMs -Both re-writing the header using Tursi's makefastboot and not doing this. Looking at the ROM with a hexeditor I don't think I should have to. -Split the ROM into U1-U4 using romsplit and write it out. I have found conflicting information. A couple posts indicate that you can use 1 MB EPROMs to make a 4 MB game, others indicate these PCBs are only compatible with 512K EPROMs to create 2 MB games. Are these compatible or not? Do I have to do anything special to get the 4 MB ROMs working on this board? Thanks. Quote Link to comment Share on other sites More sharing options...
Zerosquare Posted December 19, 2023 Share Posted December 19, 2023 Where did you get the PCB from? What do they look like? Quote Link to comment Share on other sites More sharing options...
Tenorman Posted December 19, 2023 Author Share Posted December 19, 2023 It is this one: https://www.ebay.com/itm/130888371100?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=OCU7iSyvSpa&sssrc=2047675&ssuid=ILtXf2HqQEi&widget_ver=artemis&media=COPY This is the board that Atari's romsplit.exe targets when you use the -b option. Quote Link to comment Share on other sites More sharing options...
Zerosquare Posted December 19, 2023 Share Posted December 19, 2023 (edited) This PCB is indeed designed for 2 MB, split into four 512 kB memory chips: http://mdgames.de/jaggc4ic.htm To use 27C080 chips instead, you'd need to disconnect pin #1 of the memory chips (if it's connected to +5V), and connect it to pin 5B of the cartridge slot. Edited December 19, 2023 by Zerosquare 2 1 Quote Link to comment Share on other sites More sharing options...
Tenorman Posted December 20, 2023 Author Share Posted December 20, 2023 Thank you, I was having trouble finding a definitive answer on this. 1 Quote Link to comment Share on other sites More sharing options...
