Cetmeguy Posted December 31, 2023 Share Posted December 31, 2023 I received new Harmony cart for X-Mas. It is working great, except the file order is all out of whack. I know that the order the files are copied onto the SD card will be the order that they are displayed in the Harmony menu, and I set up folders on the SD card in alphabetical order, then added roms to those folders, and they are in alphabetical order when viewed on a PC. But when viewing n the Harmony Cart in my Atari, the folders are still in alphabetical order, but the files are all over the place inside those folders. The two files I attached here show what I see on the PC versus what I see on the cart, just for the letter 'D' as an example (but it is happening on all files in the letter folders) Any thoughts? Quote Link to comment Share on other sites More sharing options...
fakecortex Posted December 31, 2023 Share Posted December 31, 2023 I believe the issue is how they were copied to the SD card. Try moving them off the card and back on all at once for each folder. I've had the same thing happen to me and I'm pretty sure that was the fix. 1 Quote Link to comment Share on other sites More sharing options...
Cetmeguy Posted December 31, 2023 Author Share Posted December 31, 2023 I managed to get the files in alpha order within each folder, and the folders are in orders as well, but when I turn on the console, the folders starts at 'R', and are alphabetically in order moving down, but the 'A' folder is on another screen. at least the games are in order, and the folders are in order, even if they don't start at 'A'. I can find the games quicker now. I'll mess around with it some more to see if I can get the folders to start on page 1 with 'A' now 1 Quote Link to comment Share on other sites More sharing options...
Prizrak Posted January 2 Share Posted January 2 There's programs that you can use to put them in alphabetical order. I think the one I've used is drivesort. Quote Link to comment Share on other sites More sharing options...
magnusfalkirk Posted January 14 Share Posted January 14 What I did was to take the folders from the Atari Nexus build, which are labled rom_2600, rom_2600h, rom_2600hb, rom_2600i, rom_2600s and rom_2600sc. I put those on the Harmony cart which at the main menu are displayed in order top to bottom. Then the games in alphabetical order within each folder. Of course the folders present original Atari 2600 games, hacks, homebrews, international, sears and supercharger games. Quote Link to comment Share on other sites More sharing options...
vjames Posted February 7 Share Posted February 7 The order is first by date/time added and secondly alphabetical. What I do: get the files I want on the SD card, move them onto my PC, erase those files on the SD card that I just moved, then move them all back to the SD card. Works like a charm! 1 Quote Link to comment Share on other sites More sharing options...
KABOOMER! Posted April 6 Share Posted April 6 Tienes razón amigo, acabo de poner orden alfabético en una carpeta donde almaceno todos los homebrews que aparecían en el cartucho Harmony en desorden, solo como iba almacenando los archivos al ingresarlos a la mico SD, tu sugerencia por fin le puso orden y concierto a la larga lista de archivos .bin , muchas gracias! Quote Link to comment Share on other sites More sharing options...
