misphitisland Posted January 3 Share Posted January 3 hello I am in here trying to get help for my problem. What i have done: bought a harmony encore. formatted sd card to fat32 installed drivers from all websites given in other forums. it is not even coming up on the programming tool but is in my pc and i can change it from what its called when it first plugged in to usb serial com3 so the problem is i have done everything suggested in most of the forums and have not had any luck when i plug it in all i get is the same screen you get when u run the 2600 with no cart in. i am lost with this an have been trying to figure it out for the last 24 hours. Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted January 3 Share Posted January 3 Are you sure your USB cable is a data cable? 1 Quote Link to comment Share on other sites More sharing options...
misphitisland Posted January 3 Author Share Posted January 3 Yes it is I was able to put videos and pics from my phone with the cable I'm useing Quote Link to comment Share on other sites More sharing options...
+xucaen Posted January 7 Share Posted January 7 Hi there. I recall similar issues with SD cards when the retron 77 came out. See if this post helps you get your SD card formatted and working... Quote Link to comment Share on other sites More sharing options...
