stushug Posted January 7 Share Posted January 7 Is this something worth having? https://www.ebay.com/itm/195718378556? Quote Link to comment Share on other sites More sharing options...
Panther Posted January 8 Share Posted January 8 It's just a copy. You can burn a PROM, EPROM, or flash chip and stick it on a cartridge board yourself. For that price they could at least include a case! Quote Link to comment Share on other sites More sharing options...
Rybags Posted January 8 Share Posted January 8 Could also put on an Atarimax flashcart though I think it needs to run as a diag mode cart so the procedure might be a bit different. Quote Link to comment Share on other sites More sharing options...
stushug Posted January 9 Author Share Posted January 9 16 hours ago, Panther said: It's just a copy. You can burn a PROM, EPROM, or flash chip and stick it on a cartridge board yourself. For that price they could at least include a case! I don't have the tools to do that. Is having that test cart worth the time and effort it would take to make one? Quote Link to comment Share on other sites More sharing options...
Panther Posted January 9 Share Posted January 9 It just depends on what you want to do with it. For diagnostics, I never found SALT to be that useful without the associated hardware board that allows checking voltages and such. If you want to do memory tests, there are much better programs available. For the color bar test, use ACP. Quote Link to comment Share on other sites More sharing options...
stushug Posted January 9 Author Share Posted January 9 3 hours ago, Panther said: It just depends on what you want to do with it. For diagnostics, I never found SALT to be that useful without the associated hardware board that allows checking voltages and such. If you want to do memory tests, there are much better programs available. For the color bar test, use ACP. Thanks! That's the kind of insight I was looking for. Quote Link to comment Share on other sites More sharing options...
