drunkeneye Posted January 14 Share Posted January 14 i am running from one problem into the next and would need help-- again... i can now load maps using xbios, and my main program looks basically like this procedure loadMap(); begin; scrname[1] := char($41+currentMap); fntname[1] := char($41+currentMap); xbunAPL (fntname, Pointer(CHARSET_ADDRESS)); xbunAPL (scrname, Pointer(TXT_ADDRESS)); end; begin asm; jsr xbios.xBIOS_SET_DEFAULT_DEVICE end; SystemOff; currentMap := 0; loadMap(); // some init stuff paintPlayer(0); Poke($D20E, 0); // turn off all IRQs repeat; asm; loop: lda skctl ; ANY KEY and #$04 bne loop lda kbcode sta ch end; MoveCurrentPlayer(ch); loadMap(); Poke($D20E, 0); // turn off all IRQs again until false; end; this works-- if i press the key to move only after loading has clearly finished. if i press the keys too fast, seemingly during xbios loading (in the background?), it somehow crashes. not sure where and especially not why. so i am sure i am missing something 'small', because i do not understand atari. can anyone help me out again? Quote Link to comment Share on other sites More sharing options...
xxl Posted January 14 Share Posted January 14 xIRQEN equ xBIOS+$3e8 ; User IRQ (1 byte) can be configured via the xB header, file or used as desired after program startup. 1 Quote Link to comment Share on other sites More sharing options...
drunkeneye Posted January 14 Author Share Posted January 14 2 hours ago, xxl said: xIRQEN equ xBIOS+$3e8 ; User IRQ (1 byte) can be configured via the xB header, file or used as desired after program startup. that is what was missing, thanks a lot!! Quote Link to comment Share on other sites More sharing options...
