Boschloo Posted January 14 Share Posted January 14 The Commodore 128 metal logo badge has fallen off. Which adhesive should I use to put it back on permanently? Quote Link to comment Share on other sites More sharing options...
carlsson Posted January 14 Share Posted January 14 Super glue? Two component epoxy glue? Unless you throw it around, I would expect the badge to sit in its place using most types of glue, though it should be one suitable for both metal and plastic. Quote Link to comment Share on other sites More sharing options...
Boschloo Posted January 14 Author Share Posted January 14 50 minutes ago, carlsson said: Super glue? Two component epoxy glue? Unless you throw it around, I would expect the badge to sit in its place using most types of glue, though it should be one suitable for both metal and plastic. I bought Kwik-Weld, we'll see how that goes. Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted January 15 Share Posted January 15 I like to use something like crafter's glue or scrapbook glue, because it does hold but also gives you the option to remove it later. 1 Quote Link to comment Share on other sites More sharing options...
eightbit Posted January 15 Share Posted January 15 (edited) Never use superglue on plastic. At worst it will melt it (the plastic, not the metal), at best it won't but you'll never get the badge off ever again! I use this thermal tape: https://www.amazon.com/gp/product/B085CLXM7J It is so thin as to not cause the badge to be "lifted", strong enough that it is not coming back off easily, but not so strong enough that you can't get the badge off one day if you really need to. I've used it to reattach original rubber feet on the machines as well. Edited January 15 by eightbit 1 Quote Link to comment Share on other sites More sharing options...
