sonicdemon11 Posted January 22 Share Posted January 22 Hey everyone! Just checking to see if anyone knew if the WICO sticks were supported on the 2600+. A local game shop near me has two mint in box and I really like the way the feel but wanted to make sure they worked. Thanks! Quote Link to comment Share on other sites More sharing options...
DEANJIMMY Posted January 22 Share Posted January 22 As any joystick with 9pol connector made for the old 8bit systems from Atari and Commodore it should work but I do not have one anymore, to test. With Sega Genesis pads you have to be careful, they have the same connector but would need an adapter like Mega7800 or Seagul to work! 1 Quote Link to comment Share on other sites More sharing options...
Mockduck Posted January 22 Share Posted January 22 Yes, I've used mine without issue. 2 Quote Link to comment Share on other sites More sharing options...
CmdrFanBer Posted April 26 Share Posted April 26 (edited) Sure, I have both the bat-handle one and the interchageable handle one and they work great on the 2600+ after 35+ years. At first I had some errors with the bat-handle Wico, as it turned out its contacts on the plug didn't make a tight fit with the pins on the 2600+. Maybe these pins are a little bit thinner or shorter than my C64's back in the day, for I used that particular joystick on that computer, or maybe it was the constant port-swapping (a quirk of C64 games). The other one (interchangeable handle) was bought used some years later for my Amiga 2000, and always stayed on port 2. Anyway, I just did a bit of gentle squeezing on the plug, and then only had trouble with the "Right" signal, so I checked the Atari DB-9 Standard diagram on WikiPedia and inserted a single, very short strand of copper wire (obtained from a small-gauge cable) in hole Nr. 4, and the joystick worked great afterwards. In fact, when I (finally) got my official Berzerk Enhanced cartridge, I used that joystick, and now I use nothing else with that game because i get higher scores with the Wico bat-handle ! Edited April 26 by CmdrFanBer typo Quote Link to comment Share on other sites More sharing options...
