Mariano DM Posted January 30 Share Posted January 30 I've put together a scrolling demo Code is pretty simple and it uses a VBI routine from compute mag. https://github.com/marianodominguez/8bit-samples/blob/master/scroll_lib/GR0SCR.TBA I'm generating 3 screens beforehand. but i wonder if it will be fast enough to generate them as we scroll. maybe having a buffer. 8ed625b9eb7569b4.mp4 5 Quote Link to comment Share on other sites More sharing options...
The Car Posted January 30 Share Posted January 30 Nice! You should be able to easily generate a new row on the fly - if not all 40 chars in one frame, you have 7-8 frames to create the next strip before it scrolls into view, so you only need to generate 5 or so chars per frame. Quote Link to comment Share on other sites More sharing options...
Rybags Posted January 30 Share Posted January 30 With the relocate string trick, all sorts of stuff is possible. Alternatively you could just about have a string of the random slashes of a couple of thousand bytes and randomly pick and place part of it which would probably be more than sufficient to create the illusion of it being totally random. Quote Link to comment Share on other sites More sharing options...
