CaptainBreakout Posted February 3 Share Posted February 3 Sweet! My Tower of Power works! Kind of. The Sega CD keeps kicking out the disc. Not reading it for some reason. Probably need to rebuild the laser or something. And the audio cuts out. Needs new capacitors all around. Anyway it runs the 32x game! The 5200 to the right is just a placeholder for now. I've got no power supply, games or controllers. The rest of the stuff on the left works tho. What you up to with your setup? Quote Link to comment Share on other sites More sharing options...
WavyGravy Posted February 3 Share Posted February 3 I just got my Sega CD back, actually, and it has the same problem! I moved across the country years ago and had to leave most of my retro stuff behind, and I was in the middle of repairing mine. Weirdly, I brought parts of it with me, so the whole machines been spread out around 4000 kilometers for a few years. I wonder if that's a record of some kind... Anyway, If I remember correctly, it has to do with some belts in the drive. The whole mechanism is weirdly over-complicated, but they just look so much cooler than the Model 2. So, I'll be tinkering with the same thing shortly, trying to remember where I was at several years ago in the middle of a repair. Should be fun? I also need to redo the grease on my PCE-CD drive sled. Already got a new middle gear and now it almost works! You can hear it at least trying to do stuff now, so that's a definite improvement. 2 Quote Link to comment Share on other sites More sharing options...
CaptainBreakout Posted February 3 Author Share Posted February 3 @WavyGravyNice. Yeah that sounds like what mine is doing. I believe it's the belts too. Where did you get your replacement parts? Console5? Quote Link to comment Share on other sites More sharing options...
WavyGravy Posted February 3 Share Posted February 3 Yes, Console 5 sells the proper belts, so no guess-work required. I buy everything I can, repair-wise, from them, honestly. They're damn good at what they do! 1 Quote Link to comment Share on other sites More sharing options...
CaptainBreakout Posted February 5 Author Share Posted February 5 Trying to get this Missile Command working for a friend. 1 Quote Link to comment Share on other sites More sharing options...
Gamemoose Posted February 15 Share Posted February 15 Fixed the right shoulder button on one of my 2DS systems. The plastic that kinda acts like a dust/debris shield got hammered and curled into the system, causing the button to barely move. I clipped the busted plastic away and now it works. Yesterday I added some electrical tape to the cage surrounding my BlueSCSI for my PowerBook 180 as I swear if the system got jostled, it would reboot. Doesn't seem to happen any more now. 2 Quote Link to comment Share on other sites More sharing options...
CaptainBreakout Posted February 19 Author Share Posted February 19 Making a homebrew POKEY 7800 cart. 1 Quote Link to comment Share on other sites More sharing options...
eightbit Posted February 20 Share Posted February 20 Finally completely finished my C64 clone. The only setback was the replacement static RAM not working with the Kawari VIC-II, but working with the Kawari developer and it now works! Its a fine machine 2 Quote Link to comment Share on other sites More sharing options...
CaptainBreakout Posted March 7 Author Share Posted March 7 (edited) Replacing the capacitors on a Pinball 2000 motherboard. This is a Star Wars episode 1. Edited March 7 by CaptainBreakout 1 Quote Link to comment Share on other sites More sharing options...
Gamemoose Posted March 12 Share Posted March 12 Two weekends ago I installed a 512K memory upgrade on my CoCo 3. Last weekend I successfully installed tbe Atari 2600 Clean Comp kit with AV wire in my VCS. It took acouple tries at soldering but all is good! 1 Quote Link to comment Share on other sites More sharing options...
CaptainBreakout Posted March 24 Author Share Posted March 24 SegaCD model 1 Got it powered. (Shorted the blown fuse) Replaced the belt. Now.. trying to get the Sony drive to read. Got the cap kit. Wish me luck. 2 Quote Link to comment Share on other sites More sharing options...
CaptainBreakout Posted April 8 Author Share Posted April 8 Here's the back of my game cabinet... For those that enjoy seeing the business end of things. Quote Link to comment Share on other sites More sharing options...
Tanooki Posted April 8 Share Posted April 8 Not much I'd want to put into pictures, finds/thrift shows the items at least, but I did two small successful resurrections of dead electronics this weekend. 1) goodwill outlet, old labtec speakers in offwhite under sound blaster name, also sold in black as the mail aways Sega did for the genesis. They were just vile on the outside, didn't even come inside bad until cleaned. The volume wheels were just shot and nearly shot, powering up was a bit ehhh... Ended up scubbing them hard with a brush and cleaner, then more with magic eraser and alcohol externally. Inside reflowed most/all the solder joints I could, even the rear of the volume wheel module, chased by soaking a brush in alcohol and scrubbing the hell out of the wheel itself inside where it attaches to de-gunk the thing. They work now, quite well, very audible more than they have a right to be at that size/age. 2) pac-man bandai tv game thing -- wouldn't power up except once. Battery rotted one connector (unpowered side) which needed vinegar and alcohol. Then the switch was really finicky so that got more alcohol and a reflow- fixed. Moved onto the touchy video that wouldn't pop up at all at first, reflowed that space, cleaned, came up...with no sound, it was like one fail after another. Did the same to the audio part, had to roll it over to the other side remove some hot glue, put new solder in a blob down to seep in the place...audio restored. So two small but utterly worthwhile personal victory fixes to keep. 2 Quote Link to comment Share on other sites More sharing options...
CaptainBreakout Posted April 14 Author Share Posted April 14 Atari Video Pinball C-380. Quote Link to comment Share on other sites More sharing options...
CaptainBreakout Posted April 14 Author Share Posted April 14 1 Quote Link to comment Share on other sites More sharing options...
Tanooki Posted April 15 Share Posted April 15 I was planning to update, but I got these games over the weekend for $3 a pop, and one of them was suffering (all Genesis games) and it was Super street fighter 2. The sound was almost gone, and I was getting background graphics glitching. Ultimately it went somewhat well at first, removed the SMC on the thing and put an appropriate cap on there to get the audio back up to where it hopefully should have been. It was like 2x louder but still low. There was anotehr ceramic cap off the chip and I tried to replace that and it didn't go well from there. I was poking about and it looks like maybe someone was in there before, not sure, but the game was either jacked up by someone before I got to it, or it was just bad from age. That particular chip wasn't even 100% lined up but just touching...ehhhh well enough to the contacts vs the legs. I pitched it, kept the shell as a replacement. Glad I have the SNES version at least. Quote Link to comment Share on other sites More sharing options...
