freetz Posted February 4 Share Posted February 4 Hi everyone, I'm trying to understand how missile/playfield collision detections (do not) work. I know that in GTIA modes 9 and 11, it is not possible to detect whether a missile has collided with playfield graphics. But I'm trying to get my head around at what stage this detection becomes no longer possible. The background if my question is that I'm only using some lines in my display list where I set PRIOR to 192 and thus enable GTIA mode 11 for these lines. This change in PRIOR is done as part of a DLI. If I remove these lines, I get the ordinary GRAPHICS 8 (ANTIC mode $0F) lines, and collision detection works as expected. I'm wondering at what stage the collision detection takes place and if it would be possible to somehow work around this. My (maybe naive) idea was to set PRIOR back to 0 as part of the VBI, so that collision detection would happen during the virtual blank and thus would not affect the image which would remain visible as GTIA mode 11. But I guess if it would have been that easy, others would have come to that conclusion way before me. OTOH, GTIA modes are rarely used, so maybe there is a slim chance that this is a solution? The other idea I had would be to test collision right after STA WSYNC, before PRIOR is set to 192. But I haven't really gotten this to work either. My assumption now is that the collision bits are set the moment the image is rendered in the Atari. So if the missile is rendered over a GTIA mode line (as it should), it is the status of PRIOR at that moment that determines whether the collision bits are set or not. If that is the case, then it wouldn't make a difference at what other time I'd change the value of PRIOR because it would either be before the rendering or after. Can anybody confirm whether these thoughts are right/wrong and if there is any other way to detect missile/playfield collision in GTIA mode 11? Thanks in advance, F. Quote Link to comment Share on other sites More sharing options...
phaeron Posted February 4 Share Posted February 4 You're correct that collision detection happens when the graphics are generated, so you can't get GTIA to "defer" collision detection to a different time with different settings. The problem is that GTIA modes 9 and 11 largely bypass the priority/collision section of GTIA. They disable the playfield layer outputs from the decoder, and tap off the player layer signals to disable the GTIA mode effects where there are P/M graphics. This is why collisions don't work and the priority of the playfield can't be controlled. Mode 10 can trigger collisions, because it works by triggering the normal P/M and playfield layers. It's of limited use due to the lack of color registers, though. 1 Quote Link to comment Share on other sites More sharing options...
freetz Posted February 4 Author Share Posted February 4 Thanks, @phaeron, at least I know I've hit a dead end here. Mode 10 is unfortunately not an option for the reason you mentioned. So I guess, I'll have to look at other ways to deal with this... Quote Link to comment Share on other sites More sharing options...
Rybags Posted February 4 Share Posted February 4 C64 has fairly poor/basic collision detection so most games make us of the bounding box method to at least enhance it. At least with GTIA modes you're dealing with fairly fat pixels so lack of precision wouldn't be a huge problem. Quote Link to comment Share on other sites More sharing options...
freetz Posted February 4 Author Share Posted February 4 Thanks, @Rybags, never heard of the bounding box method, is there anywhere I can read up on that? I assume it's somewhat mapping missile position to a playfield map, but I wonder if there is some kind of best use-case approach... Quote Link to comment Share on other sites More sharing options...
Rybags Posted February 4 Share Posted February 4 In it's simplest form, just getting the difference in X/Y position of 2 objects which can tell you if they potentially overlapping (taking into consideration h/v size for each) Of course most objects aren't just rectangular so you can either use multiple boxes per object or just give some leeway. 1 Quote Link to comment Share on other sites More sharing options...
freetz Posted February 4 Author Share Posted February 4 Thanks! Will try it that way... Quote Link to comment Share on other sites More sharing options...
