DistantStar001 Posted February 5 Share Posted February 5 (edited) I've been taking an online class, and since everyone else has setup their little backgrounds, I decided to put some of my vintage computers in mine running some looping BASIC programs on a green phosphor CRT. Obviously, since the classes run for a few hours, I don't want anything too static (screen burn, also boring), so I've been "translating" some, shall we say screen savers" in BASIC for several of my computers. I really want my Atari 800 in that mix! It's just looks awesome, and has quickly become one of my favorite 8-bit computers. However, I've run into a little issue. When left unattended for more than a few minutes, the computer goes into a screen saver mode of its own. Ironically, this puts more strain on the CRT than the little monochrome dancing lines or looping sine wave programs that I've been using. As such, I was wondering if there was a way to turn that off? Second: Also I've been running into some issues translating this BASIC program into Atari BASIC. What am I doing wrong? 20 DIM B1(50) : DIM B2(50) 30 DIM B3(50) : DIM B4(50) 50 ? “LINE SPACING”; : INPUT S 60 ? “TAIL LENGTH”; : INPUT L 80 D1=0 : D2=1 : D3=0 : D4=1 90 A1=0 : A2=0 100 A3=50 : A4=100 110 C=1 120 CC=0 130 P=0 140 E=1 150 GR. 24: SE. 2,0,1 151 COLOR 1 170 GOSUB 260 180 PLOT A1,A2 : DRAWTO A3,A4 185 COLOR 0 190 B1(P)=A1 : B2(P)=A2 : B3(P)=A3 : B4(P)=A4 200 P=P+1 : IF P=L THEN P=0 210 PLOT B1(E),B2(E): DRAWTO B3(E),B4(E) 220 E=E+1 : IF E=L THEN E=0 230 CC=CC+1 : IF CC<>5 THEN GOTO 170 240 CC=0 : C=C+1 : IF C=4 THEN C=1 250 GOTO 170 260 IF D1=0 THEN IF A1<=S THEN D1=1 : A1=1 : GOTO 300 270 IF D1=0 THEN A1=A1-S : GOTO 300 280 IF A1+S>=319 THEN D1=0 : A1=318 : GOTO 300 290 A1=A1+S 300 IF D2=0 THEN IF A2<=S THEN D2=1 : A2=1 : GOTO 340 310 IF D2=0 THEN A2=A2-S : GOTO 340 320 IF A2+S>=191 THEN D2=0 : A2=190 : GOTO 340 330 A2=A2+S 340 IF D3=0 THEN IF A3<=S THEN D3=1 : A3=1 : GOTO 380 350 IF D3=0 THEN A3=A3-S : GOTO 380 360 IF A3+S>=319 THEN D3=0 : A3=318 : GOTO 380 370 A3=A3+S 380 IF D4=0 THEN IF A4<=S THEN D4=1 : A4=1 : RETURN 390 IF D4=0 THEN A4=A4-S : RETURN 400 IF A4+S>=191 THEN D4=0 : A4=190 : RETURN 410 A4=A4+S 420 RETURN Edited February 5 by DistantStar001 Quote Link to comment Share on other sites More sharing options...
+Philsan Posted February 5 Share Posted February 5 POKE 77, 0, but you must do it every 9 minutes Quote Link to comment Share on other sites More sharing options...
DistantStar001 Posted February 5 Author Share Posted February 5 1 minute ago, Philsan said: POKE 77, 0, but you must do it every 9 minutes Wouldn't that require me to break out of the program? Also, I don't think my professor would appreciate me turning to my Atari that often during class. Quote Link to comment Share on other sites More sharing options...
Rybags Posted February 5 Share Posted February 5 Just do it inside the program once in a while. Like in the outer loop or something. 2 Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted February 5 Share Posted February 5 1 hour ago, DistantStar001 said: Second: Also I've been running into some issues translating this BASIC program into Atari BASIC. What am I doing wrong? You are trying to print to a channel, however you haven't open channel 1 yet, line 40 is trying to print A$ although A$ is empty, just comment out line 40 and the program will run ..... until the next error the PLOT/DRAW routine is failing due to some strange values in the arrays. For example B3(1) has the value 4.70136312E+15 which is one of the DRAWTO values. Both PLOT and DRAWTO cannot exceed the screen boundaries You are using GRAPHICS 8+16 hi-res mode, so the limits are for X 320-1 (319) first point is zero, so 0 to 319 limit for Y is 192-1 (191) again first point 0 so 0 to 191 Not looked into the calculations, but you must cater for the screen limits 1 Quote Link to comment Share on other sites More sharing options...
Rybags Posted February 5 Share Posted February 5 I also tried the program with not much success. With Atari Basic arrays you need to initialize the values to 0 otherwise they can potentially have random values which can screw later calculations. But I did that and it made no difference. We'd probably need to see the original program to work out what's wrong. 1 Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted February 5 Share Posted February 5 (edited) There's certainly something wrong with the logic , this is a list of values that are trying to be PLOT'd/DRAW'n effectively PLOT X,Y DRAWTO X,Y The values seem ok to start with, but soon start increasing beyond the screen max Also as @Rybags says, you're using uninitialized arrays EDIT: Maybe not, beyond MAX, bit more investigation 45 176 94 71 38 169 87 64 31 162 80 57 24 155 73 50 1 4 46 104 5 8 42 108 9 12 38 112 13 16 34 116 17 20 30 120 21 24 26 124 25 28 22 128 29 32 18 132 33 36 14 136 37 40 10 140 41 44 6 144 45 48 2 148 49 52 1 152 53 56 5 156 57 60 9 160 61 64 13 164 65 68 17 168 69 72 21 172 73 76 25 176 77 80 29 180 81 84 33 184 85 88 37 188 89 92 41 190 93 96 45 186 97 100 49 182 101 104 53 178 105 108 57 174 109 112 61 170 113 116 65 166 117 120 69 162 121 124 73 158 125 128 77 154 129 132 81 150 133 136 85 146 137 140 89 142 141 144 93 138 145 148 97 134 149 152 101 130 153 156 105 126 157 160 109 122 161 164 113 118 165 168 117 114 169 172 121 110 173 176 125 106 177 180 129 102 181 184 133 98 185 188 137 94 189 190 141 90 193 186 145 86 197 182 149 82 201 178 153 78 205 174 157 74 209 170 161 70 213 166 165 66 217 162 169 62 221 158 173 58 225 154 177 54 229 150 181 50 233 146 185 46 237 142 189 42 241 138 193 38 245 134 197 34 249 130 201 30 253 126 205 26 257 122 209 22 261 118 213 18 265 114 217 14 269 110 221 10 273 106 225 6 277 102 229 2 281 98 233 1 285 94 237 5 289 90 241 9 293 86 245 13 297 82 249 17 301 78 253 21 Edited February 5 by TGB1718 Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted February 5 Share Posted February 5 The problem is the COLOR statement, you turn it on before the loop (GOTO 170) and inside the loop, you only ever set it to zero (off) So it draws a line, then set COLOR to 0 this removes part of the line and that's it. If you change line 185 to COLOR 1 and run the program you can see the PLOT/DRAW works but it's not clearing the "tails" you'll have to figure out where to set COLOR 1 and COLOR 0 to make it look right. Also you need to put this in otherwise it prints some random lines due to the uninitialized arrays as we said before. 31 FOR I=0 TO 49:B1(I)=0:B2(I)=0:B3(I)=0:B4(I)=0:NEXT I Quote Link to comment Share on other sites More sharing options...
DistantStar001 Posted February 5 Author Share Posted February 5 Alright, it works! but not quite as expected/desired. Lines 90 and 100 are supposed to determine the length of the lines on the screen, at least they do on the Apple II, VIC-20, and BBC Micro, but on the Atari, the lines don't stay the same length growing and shrinking as the program runs. I've noticed the same issue on the C4 with Super Expander. Simon's BASIC and Extended Color BASIC do something similar but have other issues as well. The issue for the Atari is that, unlike the C64, the lines are favoring the right side of the screen and rarely make it to the left unless the lines have grown to the point where they extend all the way across the screen. I believe the issue can be resolved if I can constrain the lines to the same length but I'm not sure how to do that. Here's the revised code: 20 DIM B1(50) : DIM B2(50) 30 DIM B3(50) : DIM B4(50) 31 FOR I=0 TO 49:B1(I)=0:B2(I)=0:B3(I)=0:B4(I)=0:NEXT I 50 ? “LINE SPACING”; : INPUT S 60 ? “TAIL LENGTH”; : INPUT L 80 D1=0 : D2=1 : D3=0 : D4=1 90 A1=0 : A2=0 100 A3=50 : A4=100 110 C=1 120 CC=0 130 P=0 140 E=1 150 GR. 24: SE. 2,0,1 170 GOSUB 260 180 COLOR 1 : PLOT A1,A2 : DRAWTO A3,A4 190 B1(P)=A1 : B2(P)=A2 : B3(P)=A3 : B4(P)=A4 200 P=P+1 : IF P=L THEN P=0 210 COLOR 0 : PLOT B1(E),B2(E): DRAWTO B3(E),B4(E) 220 E=E+1 : IF E=L THEN E=0 230 CC=CC+1 : IF CC<>5 THEN GOTO 170 240 CC=0 : C=C+1 : IF C=4 THEN C=1 250 GOTO 170 260 IF D1=0 THEN IF A1<=S THEN D1=1 : A1=1 : GOTO 300 270 IF D1=0 THEN A1=A1-S : GOTO 300 280 IF A1+S>=319 THEN D1=0 : A1=318 : GOTO 300 290 A1=A1+S 300 IF D2=0 THEN IF A2<=S THEN D2=1 : A2=1 : GOTO 340 310 IF D2=0 THEN A2=A2-S : GOTO 340 320 IF A2+S>=191 THEN D2=0 : A2=190 : GOTO 340 330 A2=A2+S 340 IF D3=0 THEN IF A3<=S THEN D3=1 : A3=1 : GOTO 380 350 IF D3=0 THEN A3=A3-S : GOTO 380 360 IF A3+S>=319 THEN D3=0 : A3=318 : GOTO 380 370 A3=A3+S 380 IF D4=0 THEN IF A4<=S THEN D4=1 : A4=1 : RETURN 390 IF D4=0 THEN A4=A4-S : RETURN 400 IF A4+S>=191 THEN D4=0 : A4=190 : RETURN 410 A4=A4+S 411 POKE 77,0 420 RETURN Notes: COLOR statements are integrated into the PLOT/DRAWTO lines 180 and 210. Also, the POKE statement was added to the loop at line 411. I tried line 151, but soon learned that it needed to be with in the loop to be executed as needed. I'm guessing that it could have been added anywhere in the loop between lines 260 and 420, but after 410 just felt right. My thanks for all the help so far. 1 Quote Link to comment Share on other sites More sharing options...
dmsc Posted February 6 Share Posted February 6 (edited) Hi! 14 hours ago, DistantStar001 said: Alright, it works! but not quite as expected/desired. Lines 90 and 100 are supposed to determine the length of the lines on the screen, at least they do on the Apple II, VIC-20, and BBC Micro, but on the Atari, the lines don't stay the same length growing and shrinking as the program runs. I've noticed the same issue on the C4 with Super Expander. Simon's BASIC and Extended Color BASIC do something similar but have other issues as well. The issue for the Atari is that, unlike the C64, the lines are favoring the right side of the screen and rarely make it to the left unless the lines have grown to the point where they extend all the way across the screen. I believe the issue can be resolved if I can constrain the lines to the same length but I'm not sure how to do that. I don't see it in the program you posted, lines don't grow and go to both sides of the screen. Here is a BAS file you can try: lines.bas I also converted your program to FastBasic for a faster experience, attached is the source and compiled binary. Have Fun! lines2.xex lines2.fb Edited February 6 by dmsc 1 Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted February 6 Share Posted February 6 On real hardware or ? Quote Link to comment Share on other sites More sharing options...
DistantStar001 Posted February 6 Author Share Posted February 6 1 hour ago, _The Doctor__ said: On real hardware or ? Real. Atari 800. Quote Link to comment Share on other sites More sharing options...
