rdefabri Posted February 8 Share Posted February 8 My apologies if this has been covered before - I have a neat idea for a game that is certainly within my abilities to create. I'm hardly a programmer, and I'm a dinosaur (I'm out of the loop, my professional career is Marketing), hence the ask. Is there a simple Windows-based development environment that I can use to code / run / test programs for the A8 line? I'd like to do this program in Atari BASIC, and typing / testing / saving on a real A8 - or even an emulator - is tedious. I'm pretty sure tools exist, but I'm a real thickhead - I need a lot of hand holding to understand what is needed as I'm only somewhat technical. Any guidance would be appreciated - I keep trying to come back to this, then get discouraged, but I think this time I can pull this off. Thanks! Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted February 8 Share Posted February 8 Not sure about a BASIC environment outside of the emulators, but other languages are catered for, Assembler has several for example MADS, also ca65, there is also Pascal and C. All the above still need to run in an emulator, but the environment can be set to launch the emulator to run your code. 1 Quote Link to comment Share on other sites More sharing options...
popmilo Posted February 8 Share Posted February 8 "8Bitworkshop" got much much better recently, has huge choice of platforms to develop for, examples and built in emulator. And all that in a browser, so no install needed: https://8bitworkshop.com/v3.11.0/?platform=atari8-800&file=joyas.bas 3 Quote Link to comment Share on other sites More sharing options...
rdefabri Posted February 8 Author Share Posted February 8 1 hour ago, popmilo said: "8Bitworkshop" got much much better recently, has huge choice of platforms to develop for, examples and built in emulator. And all that in a browser, so no install needed: https://8bitworkshop.com/v3.11.0/?platform=atari8-800&file=joyas.bas Looks interesting. I've been primarily trying with Notepad, but I don't know if there's a copy / paste command for Altirra. At least that lets me code / debug but it's not as easy as an IDE. Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted February 8 Share Posted February 8 1 hour ago, rdefabri said: but I don't know if there's a copy / paste command for Altirra. Yes there is, you can copy in notepad and paste into the Altirra screen. If you want to do the reverse, under View dropdown, select Printer Output and a window will appear, now any output sent to the printer will appear here. Highlight any text in that window and press CTRL-C to copy the text, then paste into a text editor in Windows. A better editor is Notepad++ or even Programmers Notepad 2 Quote Link to comment Share on other sites More sharing options...
rdefabri Posted February 8 Author Share Posted February 8 1 hour ago, TGB1718 said: Yes there is, you can copy in notepad and paste into the Altirra screen. If you want to do the reverse, under View dropdown, select Printer Output and a window will appear, now any output sent to the printer will appear here. Highlight any text in that window and press CTRL-C to copy the text, then paste into a text editor in Windows. A better editor is Notepad++ or even Programmers Notepad This helps quite a bit - thank you! Quote Link to comment Share on other sites More sharing options...
Irgendwer Posted February 8 Share Posted February 8 8 hours ago, rdefabri said: I'd like to do this program in Atari BASIC, and typing / testing / saving on a real A8 - or even an emulator - is tedious. I guess "Turban" is for you: (Atari Basic is also supported...) 1 Quote Link to comment Share on other sites More sharing options...
