sideburn Posted February 10 Share Posted February 10 Hey All, I have a Gotek drive with a single cable that plugs into the ST and its working find but I also have an SF314 and if I chain the Gotek off it it will be Drive B and I think most game disk images want to be on drive 0 correct? and any disk images with an Auto folder won't boot on power up. Is there a way to assign the SF314 as Drive 0 ? Or a way to make a connector so I can plug the SF314 into the Gotek instead? Quote Link to comment Share on other sites More sharing options...
351cougar Posted February 10 Share Posted February 10 you didnt mention the type of ST this is? ie all machines with no internal drive were set to support 2 external daisy chain drives, while systems with an internal drive were jumpered for that drive to be A and external as B . The GOTEK manual should have something defining itself and passthru floppy id. Quote Link to comment Share on other sites More sharing options...
sideburn Posted February 10 Author Share Posted February 10 (edited) Ooops. Sorry. This is a 520 STm so no internal drive. The gotek is set to drive 0 and when I plug into the back of the ST it works as drive A and auto boots disk images with a org in the Auto directory. The problem is when I plug the SF314 in, it is now drive A and the Gotek plugged into the OUT jack of the SF314 makes it become drive B. I meant to ask if there’s a way to make the SF314 drive 1 (not 0) so it will become the B drive and the Gotek can be the A drive. Edited February 10 by sideburn Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted February 10 Share Posted February 10 I think the only way would be to do some surgery in the SF314 to fit a switch to swap the D0/D1 select lines, I did something like that bitd when I had an SF314 and a 5 1/4" external floppy on my 520STM. I actually had 2 other third party 3 1/2" DS drives also fitted, but obviously could only use any 2 at the same time. Quote Link to comment Share on other sites More sharing options...
TZJB Posted February 10 Share Posted February 10 13 hours ago, sideburn said: Hey All, I have a Gotek drive with a single cable that plugs into the ST and its working find but I also have an SF314 and if I chain the Gotek off it it will be Drive B and I think most game disk images want to be on drive 0 correct? and any disk images with an Auto folder won't boot on power up. Is there a way to assign the SF314 as Drive 0 ? Or a way to make a connector so I can plug the SF314 into the Gotek instead? There is no easy fix for this as Drive Select is a physical connection from the individual drive select pins of the unbuffered Atari ST Yamaha YM2149 sound chip pins 19 & 20. They connect to the floppy drive DIN connector pins 5 & 6 so a changeover switch anywhere in those lines or in the disk drive itself would achieve your requirement as @TGB1718 suggested. As you will see below, within the SF-314 DIN14 IN J5 pin 6 of the disk drive swaps to pin DIN14 OUT J6 pin 5 so a changeover switch there is probably the simplest. As I don't think that I have an SF-314, I cannot advise on the best way to do that but you would probably need a miniature double pole changeover switch. From their respective Service Manuals:- Quote Link to comment Share on other sites More sharing options...
sideburn Posted February 10 Author Share Posted February 10 Ah, probly not worth mucking with the SF314. Do some ST games and software require booting from drive A? I suppose I will juts disconnect the SF314 when using the Gotek. Maybe it is polssible to make and in/out connector and plug the SF314 into the OUT din of that? Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted February 11 Share Posted February 11 (edited) Maybe a solution would be to buy a second SF314 (maybe a faulty one so it's cheap) and mount the Gotek in that case I actually have a GOEX and that's mounted in my SF314 case. Edited February 11 by TGB1718 Quote Link to comment Share on other sites More sharing options...
sideburn Posted February 11 Author Share Posted February 11 Eh. I already made a case 😝 Quote Link to comment Share on other sites More sharing options...
TZJB Posted February 15 Share Posted February 15 On 2/10/2024 at 10:09 PM, sideburn said: Ah, probly not worth mucking with the SF314. Do some ST games and software require booting from drive A? I suppose I will juts disconnect the SF314 when using the Gotek. Maybe it is polssible to make and in/out connector and plug the SF314 into the OUT din of that? The Atari ST will boot from Drive A by default unless a hard drive is detected. That is why a changeover switch, connected within the Atari ST, is so useful. I used a latching push button DPDT switch to achieve this and mounted it on the rear panel in a right hand position. The purpose of this at the time was to allow a 720KB 5.25" A drive which imitated a 720KB 3.5" drive but used cheaper floppy disks from the Atari 8 bit! The Atari ST is heavy enough to allow push button use without it moving! For instance something like https://www.ebay.co.uk/itm/382852458373 is similar to the switch I used to swap and restore the YM2149 pins 19 and 20, but any DPDT switch will work. 1 Quote Link to comment Share on other sites More sharing options...
sideburn Posted February 15 Author Share Posted February 15 Yeah I have an SF314 connected and I put A power switch on the back of the Gotek enclosure. But I can also push in the rotary controller to "eject" a disk image and boot from the HD. I mainly just wanted to be able to have the SF314 connected to the chain as drive B. Maybe I will find a broken SF314 for parts some day. Quote Link to comment Share on other sites More sharing options...
MrMaddog Posted February 17 Share Posted February 17 You can also try DC BootIt which lets you boot from Drive B: from the GEM desktop. I used it when I had a hard drive connect and wanted to boot into a game w/o restarting the compupter. It's from this website on the Tools & Utilities disk. 1 Quote Link to comment Share on other sites More sharing options...
sideburn Posted February 18 Author Share Posted February 18 That sounds interesting, I’ll try it! I thought maybe I would just copy from Gotek on B to floppy on A but then discovered some game disk images are encrypted or something where they show zero contents but they boot from A and run. Quote Link to comment Share on other sites More sharing options...
