Duodisk issue
KyleP
My Duodisk drive  on my Apple IIe has stopped working.  I was checking blank disks to see if anything was on them and I was quickly turning the computer off, inserting new disk, then switching it on again to load the next disk.  After doing this a few times the disk stopped reading.  What happens is when the computer is turned on the motor clicks and the disk spins but the read/write head does not move and nothing loads.  I have reseated the chips, tried using the mechanical part of another drive and the same thing happens.  I believe my issue is with the analog board.  Can anyone point me in the right direction as to what to try next?  Change a specific chip?  Im not very educated in electronics so Not sure how to test anything.
Thanks for any advice.
Update-  I tried swapping out multiple disk drives and a floppy emu.  The first time the computer starts it loaded a disk from the different drives.  It will not load another after that if I do a keyboard reset or when i turn the computer off and back on.   The floppy emu will load another disk only with a keyboard reset.
I have tried 2 different duodisk drives and 3 single drives,  One of the single drives works fine but the others are not working.  The all worked up until this point.  I have no idea what is going on.   Why would 4 different drives fail and one work?
This sounds like you have bad diskettes (or at least one bad diskette) that is fouling the read-write head.
I would suggest that you use a cotton swab soaked in isopropyl alcohol or my favourite solution, "zippo" lighter fluid (aka Ronsonol).
If there is any brown residue on the swab then your diskettes have mould on the surface of the media and are ruined.
Inspect one of the disks that doesn't read.  Does it have a faint concentric scratch at the outer circumference?  If so, then that diskette is trashed.
Thats exactly what it was.  Lost 3 good disks in this experience.   I thought I had cleaned the heads but it was not good enough.  I used some elbow grease and now the drive is reading again.   Thanks
Be careful. Old diskettes, more often than not are mouldy.  I keep a single disk drive on my bench with the cover off and that's the drive I use to read suspect disktettes.
It gets cleaned after every read, and if there is any sign of residue that disk gets imaged immediately and discarded.
+1
+1
Only way to deal with unknown disks.  Disks are guilty until proven innocent.
