Pixel_Outlaw Posted February 12 Share Posted February 12 Hello All, So I've just purchased a Ti/99 and being a pretty hardcore programmer I wanted to get started. I found out that I didn't have (it seems) enough memory to run much with a stock TI so I purchased a 32k memory upgrade from The Brewing Acadamy. I also purchased a FinalGROM cart to store the TurboForth cart on. Unfortunately I'm seeing the error below. I do know that on emulator it boots with the TurboForth logo showing. Also I'd be interested in purchasing a real Forth cart (I saw a few implementations) but I'm not sure if they require additional hardware. I can only write to tape currently for storage, I'm a bit tapped out for cash after the RAM and FinalGROM upgrades. I'm a hardcore Lisp fan but Forth sure seems interesting from what I've poked in. 2 Quote Link to comment Share on other sites More sharing options...
atrax27407 Posted February 12 Share Posted February 12 Do you have the BLOCKS file in DSK1? 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted February 12 Share Posted February 12 16 minutes ago, Pixel_Outlaw said: Hello All, So I've just purchased a Ti/99 and being a pretty hardcore programmer I wanted to get started. I found out that I didn't have (it seems) enough memory to run much with a stock TI so I purchased a 32k memory upgrade from The Brewing Acadamy. I also purchased a FinalGROM cart to store the TurboForth cart on. Unfortunately I'm seeing the error below. I do know that on emulator it boots with the TurboForth logo showing. Also I'd be interested in purchasing a real Forth cart (I saw a few implementations) but I'm not sure if they require additional hardware. I can only write to tape currently for storage, I'm a bit tapped out for cash after the RAM and FinalGROM upgrades. I'm a hardcore Lisp fan but Forth sure seems interesting from what I've poked in. As far as I know all the Forth systems for TI-99 expect a disk drive. That was always the classical Forth system back in the early days. Forth was the CPU, RAM, I/O devices (terminal) and virtual memory disk system. So you can explore a lot of stuff in the kernel, but you can't save anything as far as I know. LISP and Forth are similar but Forth is waaaay lower level out of the box. However your LISP training of factoring your programs into small functions holds. Actually even more so. Forth favours small named routines to simplify stack parameter gyrations. It gets away with that because calling overhead is quite low. You will probably use some colourful language in the course of exploring Forth. You might find that you begin "backing talkwards". Welcome to the party. 2 1 Quote Link to comment Share on other sites More sharing options...
Reciprocating Bill Posted February 12 Share Posted February 12 (edited) Wycove Forth 2.0 was designed to run from a cassette if necessary, although hard to imagine how useable that would be. An E/A, MiniMemory or Extended Basic module and 32K are also required. The error in your screenshot is the error TurboForth gives when it can't find a Blocks file. Edited February 12 by Reciprocating Bill 2 Quote Link to comment Share on other sites More sharing options...
Pixel_Outlaw Posted February 12 Author Share Posted February 12 Thank you guys for your insight! Ahhh shoot. So I'm going to have to purchase either a real disk drive or another virtualized solution. I imagine a virtualized solution is best. Is there anything in stock anywhere? Thanks for the warm welcome! Quote Link to comment Share on other sites More sharing options...
+TheBF Posted February 13 Share Posted February 13 TIPI is good but I don't know the price. 1 Quote Link to comment Share on other sites More sharing options...
RickyDean Posted February 13 Share Posted February 13 1 Quote Link to comment Share on other sites More sharing options...
GDMike Posted February 19 Share Posted February 19 Yes I agree TIPI is your best bet since you would need a disc controller card and a floppy drive at minimum, where as tipi solves that And actually expands into network file saveability. Just remember FBforth, camel forth and turbo forth are supported today. Definitely worth getting extra hardware and F18A. Quote Link to comment Share on other sites More sharing options...
