DevBR Posted February 14 Share Posted February 14 (edited) I'm setting up a labyrinth where the player (ball) must travel through a labyrinth, respecting the Playfield limit.  It is working, however, when it touches the Playfield, it stops when it should actually slide against the Playfield. 😔  Attached is the full source code, just put it in Batari and run it to identify what I said.  Could anyone give me an idea of how to change the source code to make the BALL slide on the playfield?  Below is a brief explanation of the code: Depending on the movement of the Joystick, I will move the Ball to the desired destination and put 1 in a variable that moved to that side (for example, if it went DOWN, then d = 1). Then I will test the collision of the BALL with the PLAYFIELD, if it is true, I see which variable has the value 1 and return the BALL to the previous position.  loop if collision(playfield,ball) && d = 1 then bally = bally - 1: d = 0 if collision(playfield,ball) && r = 1 then ballx = ballx - 1: r = 0 if collision(playfield,ball) && l = 1 then ballx = ballx + 1: l = 0 if collision(playfield,ball) && u = 1 then bally = bally + 1: u = 0 if joy0down then bally = bally + 1: d = 1 if joy0right then ballx = ballx + 1: r = 1 if joy0left then ballx = ballx - 1: l = 1 if joy0up then bally = bally - 1: u = 1 drawscreen goto loop  lab_better.bas  Edited February 14 by DevBR Two uploaded files Quote Link to comment Share on other sites More sharing options...
DevBR Posted February 15 Author Share Posted February 15 Hello, I discovered a way to make the movement I needed. I debugged the Adventure game and found that the movement occurred in 1 frame and the next two frames were collision tests. Thanks! Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted February 15 Share Posted February 15 Remember that you can do just one "collision(playfield,ball)" check to save cycles. Â Something like if !collision(playfield,ball) then goto _Skip_Collision_PF_Ball" then have your other checks sandwiched in there. Quote Link to comment Share on other sites More sharing options...
DevBR Posted February 15 Author Share Posted February 15 4 hours ago, Random Terrain said: Remember that you can do just one "collision(playfield,ball)" check to save cycles. Â Something like if !collision(playfield,ball) then goto _Skip_Collision_PF_Ball" then have your other checks sandwiched in there. Hi Random Terrain, Â Thank you very much for your tip. I did not know that. Â I discovered that the collision does not change the value in the same cycle (frame) only when I started the Debug on Adventure on Stella emulator. Â I appreciate your help! Â Best Regards. 1 Quote Link to comment Share on other sites More sharing options...
