rdefabri Posted February 20 Share Posted February 20 I forgot how simultaneously frustrating and enlightening programming could be (although I suck, so it's more frustrating than enlightening). Creating PM graphics in Atari BASIC is simple enough - the POKEs to set up virtually everything, including horizontal movement, are all there. It's obviously vertical movement that becomes an issue, and standard practices yield a much slower moving sprite moving up / down. There are known machine language VBI subroutines, and I can get them to work. However, I have some issues when I determine a collision (in this case, PM0 to playfield) - if I end the program, the PM stays on screen and when I go to run again, the program is corrupted and/or doesn't run. So a few questions - is there a standard way to clear all the memory out and reinitialize? I've tried CLR, and even loops to zero out everything. No dice. The other question I have is that the VBI subroutines I've leveraged (mostly from Atari BASIC programming books) use lengthy DATA statements. Not a big deal per se, but if I were ever to attempt a 10-line BASIC game, it's a non-starter...is there some simplified or smaller machine code subroutine to handle fast vertical movement? I know the simple answer is to use a different BASIC. BASIC XE and Altirra BASIC have built in PM commands that make it easier, but now I'm hellbent on doing this in BASIC. Any advice? Quote Link to comment Share on other sites More sharing options...
Preppie Posted February 20 Share Posted February 20 Machine language subroutines are not allowed in the 10 liner BASIC competition. It's possible to use strings to move players faster vertically but it's a little tricky and has a lengthy setup routine. Info can be found here: Or you could design a game around your limitations eg. just have players move horizontally. 1 Quote Link to comment Share on other sites More sharing options...
rdefabri Posted February 20 Author Share Posted February 20 (edited) 1 hour ago, Preppie said: Machine language subroutines are not allowed in the 10 liner BASIC competition. It's possible to use strings to move players faster vertically but it's a little tricky and has a lengthy setup routine. Info can be found here: Or you could design a game around your limitations eg. just have players move horizontally. Yep I know you can't use machine language in 10-Liner, I kind of gave up on that until I can actually program something that works! Edited February 20 by rdefabri Quote Link to comment Share on other sites More sharing options...
Irgendwer Posted February 20 Share Posted February 20 31 minutes ago, Preppie said: just have players move horizontally. ...or don't move them at all: 😁 1 1 Quote Link to comment Share on other sites More sharing options...
