Atari 1020 Plotter DIY replacement Pens(RetroHax.net)
In case some of you 1020 Plotter owners have not seen, RetroHax.net posted a very nice blog post on making new pens for the Atari 1020 Plotter
https://retrohax.net/atari-1020-plotter-plotting-pens-replacement/
Here is more info on how you can make your own.
First you will need to 3D print the Pen cases using the RetroHax.net STL files
He used a Resin Printer, but I printed them on a FDM Ender 3 printer with PLA Filament
I printed them pen tip side up, on a Raft at 100% infill
For pens, i was not able to get the pens RetroHax.net used as I am in the US, the best I could find were these from amazon:
https://www.amazon.com/dp/B07F814H3X?psc=1&ref=ppx_yo2ov_dt_b_product_details
For cutting the pen inserts I made a 3D printed Jig for cutting them with a razor blade. You can download the STL file for the jig here:
https://www.thingiverse.com/thing:6497069
Clean out the hole in the 3D printed pen case with a 7/64th drill bit
Push the pen insert into the case with a total length of about 23.50mm
The amazon pens are cheap, and are gel ink, but they are not perfect.They require a bit too mush pressure to write all that great. On the flip side, another pen I tried drawed ok, but smeared really, really bad. I am on a lookout for something better, and will post here when I do
If you find a better pen, please post it here.
  • Like 16
  • Thanks 2
Hello Fierodoug5
23 hours ago, Fierodoug5 said:
I keep hearing new pens are made, but have never seen anyone link to any that were not just old NOS pens
I found two sources, but both are in German(y):
http://plotterstifte-faserschreibfedern.de/K5208-Medizinschreiber-4er-Paket
https://www.evident-shop.de/diagnostik/plotterstifte/249/plotterstifte/schreibstift-sortiment-in-den-farben-rot-blau-gruen-schwarz
Sincerely
Mathy
  • 2 weeks later...
When I was working on the same idea I found most of the pens were too fat to get through the return spring on the front so it would never reach the page. Well done actually getting this to work properly!
Hello Fierodoug5
On 2/23/2024 at 2:14 PM, Fierodoug5 said:
Cool, now we just need someone in Germany to try them and report back
I found the links on the ABBUC Forum, somebody already tested them.  They work!
Sincerely
Mathy
Gotta try this when I get the chance. My 1020 has been collecting dust because only the red pen works. Looks better than the Pilot BPS pen refill method since you don't need the original pen cases.
