Gordo Posted February 23 Share Posted February 23 Hello all So I just picked up a PEB. I have a couple basic questions. First off is there any method or proper order for the cards? I know the main controller card goes in slot one. I also have a disk drive card, a 32K card and a RS232 card. Does it matter what slot I put them in? Also does anyone have a recommended cooling fan to buy to replace the noisy one? Many thanks Quote Link to comment Share on other sites More sharing options...
RickyDean Posted February 23 Share Posted February 23 The Interface card generally goes in slot 1, furthest from the floppy drive opening. The disk controller should go closer to the floppy drive. Other than that, you can place them as you see fit. Back in the day a large 12 volt fan that was about the size of the one in the unit, only quieter, was the way to go. But many today just leave it loud as it adds to the "nostalgic" feeling. 2 Quote Link to comment Share on other sites More sharing options...
Gary from OPA Posted February 23 Share Posted February 23 Yeah I like the original fan noise. Normally the flex card goes in the first slot next to the power area as originally some have a ground screw in the back connector part. The floppy controller was designed to go in the slot against the drive bay but I normally leave it in the next slot over so I have a tiny bit of room to unplug the cable without removing the floppy drive. Of course doing that means if you filling up all 8 slots like I do then you need to put a card into the 8th slot that doesn't have anything coming out the back, so I usually put my old Horizon or PGram card there. 1 Quote Link to comment Share on other sites More sharing options...
RXB Posted February 23 Share Posted February 23 I got sick of the noise from the P-Box so bought the Shift838 P-box card and replaced it with a PC case. That PC case has TIPI (PI 3+), Corcomp Disk Drive card One 3.5 Floppy drive SAM 1Meg Card Speech Card with Shift838 adaptor Shift838 Interface Card and cable. 350 Watt Power supply The case has 3 120mm silent fans which makes it super silent and very cool to run. 8 Quote Link to comment Share on other sites More sharing options...
GDMike Posted February 24 Share Posted February 24 I liked the noise, but unfortunately my 10lb transformer went bad, so I had to transform the peb to noiseless 12vdc fan and PC ps. It's ok. 1 Quote Link to comment Share on other sites More sharing options...
Reciprocating Bill Posted February 24 Share Posted February 24 I replaced my PEB fan. If I'm feeling nostalgic I run the Kirby. 1 Quote Link to comment Share on other sites More sharing options...
+FALCOR4 Posted February 25 Share Posted February 25 I've been using the Wathai 110V 115V 120V 220V 240V Brushless Fans <80mm x 25mm> from Amazon. They're an easy replacement and are about (subjective here, mind you) half the noise of the OEM fan. 1 Quote Link to comment Share on other sites More sharing options...
horizon2374 Posted March 8 Share Posted March 8 I have my cards arranged as follows: 1 - Flex cable interface 2 - 32K memory expansion 7 - RS-232 interface 8 - Corcomp DS/DD disk controller …this way it balances the cards out side-to-side, but I think I should move the RS-232 to slot 6 and the Corcomp controller to slot 7 to make it easier to remove the floppy cable if needed when removing the controller card. But come to think of it… do you think it’s better to give space between each card to promote better air flow and produce less heat between them? If so the card arrangement would be: 1 - Flex cable interface 3 - 32K memory expansion 5 - RS-232 interface 7 - Corcomp DS/DD disk controller Then there is that elusive UCSD Pascal card… 😊😊 Quote Link to comment Share on other sites More sharing options...
