Retrospect Posted February 28 Share Posted February 28 WTF-G.BIN 11 4 2 Quote Link to comment Share on other sites More sharing options...
jrhodes Posted February 28 Share Posted February 28 It's not even April yet 1 Quote Link to comment Share on other sites More sharing options...
+mizapf Posted February 28 Share Posted February 28 I could not get it running in MAME yet; what kind of cartridge is that? ROM or GROM data? Quote Link to comment Share on other sites More sharing options...
Retrospect Posted February 28 Author Share Posted February 28 (edited) 5 hours ago, mizapf said: I could not get it running in MAME yet; what kind of cartridge is that? ROM or GROM data? It's been created using senior falcon's "makecartG" utility. I think it works on Final Grom? I would have attempted an RPK but I just cannot get my head around the layout file and what things are meant to be in there. I will keep trying that though! Edit: I just went onto my folders to get you the fiad file to put it into a DSK image that I knew would run under MAME and it appears i've binned the source, binned all my fiads and emptied the bin earlier during a cleanup. I should never do this but then again I can't stand "hoarding" on my pc! Sorry about that. Edited February 28 by Retrospect 1 Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted February 28 Share Posted February 28 1 hour ago, Retrospect said: It's been created using senior falcon's "makecartG" utility. If you can create ROMs rather than GROMs, these could be burned to cartridges. 2 Quote Link to comment Share on other sites More sharing options...
Shift838 Posted February 28 Share Posted February 28 cute game.. 1 Quote Link to comment Share on other sites More sharing options...
OX. Posted February 28 Share Posted February 28 3 hours ago, Retrospect said: It's been created using senior falcon's "makecartG" utility. I think it works on Final Grom? I would have attempted an RPK but I just cannot get my head around the layout file and what things are meant to be in there. I will keep trying that though! Edit: I just went onto my folders to get you the fiad file to put it into a DSK image that I knew would run under MAME and it appears i've binned the source, binned all my fiads and emptied the bin earlier during a cleanup. I should never do this but then again I can't stand "hoarding" on my pc! Sorry about that. Here you go. JOE.dsk 1 1 Quote Link to comment Share on other sites More sharing options...
+mizapf Posted February 28 Share Posted February 28 OK, this is working; it must be loaded in Extended Basic. What does makecartG create from it? Is this intended to be run on the FinalGrom only? Quote Link to comment Share on other sites More sharing options...
Retrospect Posted February 28 Author Share Posted February 28 39 minutes ago, mizapf said: What does makecartG create from it? Is this intended to be run on the FinalGrom only? far as i know but others will know better than i. Quote Link to comment Share on other sites More sharing options...
SteveB Posted February 28 Share Posted February 28 1 hour ago, mizapf said: OK, this is working; it must be loaded in Extended Basic. What does makecartG create from it? Is this intended to be run on the FinalGrom only? MakecartG creates a GROM based module compatible with the v2.2 console, makecart8 creates a more versatile ROM based module. Both basically disables the 32k memory extension and works out of VRAM to make a dump of the 32k extension. Details can be found in the XB GEM Manual. 3 Quote Link to comment Share on other sites More sharing options...
+eebuckeye Posted February 29 Share Posted February 29 Can't get it to work with JS99er.. hm.. Quote Link to comment Share on other sites More sharing options...
Retrospect Posted February 29 Author Share Posted February 29 1 hour ago, eebuckeye said: Can't get it to work with JS99er.. hm.. Use Load Cart option and then choose the file that way. Ensure 32K is enabled although I think it always is by default. Other than that I don't know? It works fine for me in 99er. 1 Quote Link to comment Share on other sites More sharing options...
+eebuckeye Posted February 29 Share Posted February 29 Redownloaded and it works great.. very cool! 1 Quote Link to comment Share on other sites More sharing options...
