Siliconburn Posted March 10 Share Posted March 10 So I just got around to flashing my fujinet 1.5 from version 1.1 to 1.2. The hardware I have needs the 8MB firmware. This is the first time I've flashed, followed the instructions and watched the flashing, no errors and under the log it showed it boot, showed the new firmware version and displayed all of the settings i had setup under the 1.1 version. I disconnected and hooked it backup to my 800XL and it boots to the ready prompt. I even tried for grins adding a microUSB for power to it with no change. It powers up and the orange light is steady. I re-flashed and got the same result. Am I missing something? I can open a web browser and access the web interface, it shows the version being 1.2 and hsio is set to 6, which is what it was prior to flashing. I'v added screen grabs from the web page of the configuratiion. Sorry if I missed this posted somewhere else, when searching I did not come across anything. Thanks for any assistance in this. Quote Link to comment Share on other sites More sharing options...
+DjayBee Posted March 10 Share Posted March 10 I guess that without logs - collected by the flasher tool while running FujiNet - nobody can help you in a useful manner. Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted March 10 Share Posted March 10 Pick a different revision to flash, and try different usb cables. Remember to turn off the fujinet until just before flashing, then turn it on... certain FujiNets don't flash or won't flash properly if you take too long after powering up. make sure the usb serial speed in the flasher app is correct speed. and flash it. Quote Link to comment Share on other sites More sharing options...
Siliconburn Posted March 10 Author Share Posted March 10 12 hours ago, DjayBee said: I guess that without logs - collected by the flasher tool while running FujiNet - nobody can help you in a useful manner. The flash was successful, I'm sorry for no logs, other than what shows on the screen when flashing I'm not familiar with where it creates the log file. If I had known, it wasn't going to work, I would have copied off that screen. 7 hours ago, _The Doctor__ said: Pick a different revision to flash, and try different usb cables. Remember to turn off the fujinet until just before flashing, then turn it on... certain FujiNets don't flash or won't flash properly if you take too long after powering up. make sure the usb serial speed in the flasher app is correct speed. and flash it. I'll try going back to 1.1 and see what happens, I'll try to capture the logs just in case this time. Quote Link to comment Share on other sites More sharing options...
+DjayBee Posted March 10 Share Posted March 10 19 minutes ago, Siliconburn said: The flash was successful, I'm sorry for no logs, other than what shows on the screen when flashing I'm not familiar with where it creates the log file. If I had known, it wasn't going to work, I would have copied off that screen. I meant logs from the Fujinet running. Keep it connected to the PC and "switch" the flasher tool into logging mode. Then try to use it from the Atari. You will see lots of log data showing up which will hopefully be useful in finding the problem. Quote Link to comment Share on other sites More sharing options...
mozzwald Posted March 10 Share Posted March 10 1 hour ago, Siliconburn said: I'll try to capture the logs just in case this time. There's a section on the wiki about capturing debug output https://github.com/FujiNetWIFI/fujinet-firmware/wiki/FujiNet-Flasher#capturing-serial-debug-output This would help us try to figure out what the issue is on the latest firmware Quote Link to comment Share on other sites More sharing options...
