+x=usr(1536) Posted March 25 Share Posted March 25 There's an issue with filename length that I ran across while looking into some fujinet-pc stuff. It may be related to https://github.com/FujiNetWIFI/fujinet-config/issues/25, but seemed like it was worth mentioning here since it wasn't clear if that was the case or not. Abstract: while browsing a tnfs server, overly-long filenames (including the path) cause unexpected behaviour. Note the first screenshot below: After clicking on the highlighted link, the following appears: This is effectively an empty version of the directory in which the file resides. The directory clearly isn't empty because there are files listed in it in the first screenshot Clicking on the download arrow serves a completely blank (i.e., no HTML) page. Clicking on the 'S' at the end of the path has no effect, though the other parts of the pathname are navigable. The fujinet-pc build on the remote machine is a git clone from yesterday; browsers in use on the local side are current versions of Brave, Firefox, and Safari under macOS 13.6.5 (Ventura) on x64. All three browsers display the same behaviour. Quote Link to comment Share on other sites More sharing options...
apc Posted March 25 Share Posted March 25 What a long file names! 🙂 To handle them in WebUI, I've increased buffer size for encoded and html escaped file names. The change is in repository now. Thanks for reporting! -jan Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted March 25 Share Posted March 25 I wrote a book and published it as a filename. Why can't I read it? 3 Quote Link to comment Share on other sites More sharing options...
+x=usr(1536) Posted March 25 Author Share Posted March 25 1 hour ago, apc said: What a long file names! 🙂 Yep That's actually how they come out from the .zip file; they just happened to show up the issue. 1 hour ago, apc said: To handle them in WebUI, I've increased buffer size for encoded and html escaped file names. The change is in repository now. Thanks for reporting! -jan Thank you! Quote Link to comment Share on other sites More sharing options...
Mr Robot Posted April 6 Share Posted April 6 I had to rename a bunch of the paths on my tnfs because of that (rename "Adventure International" to "AI" for example), it also stopped the Homebrew awards entries being available for some of the files. Also falls through to the access logs with any path over something like 170 characters having its name truncated. 2 Quote Link to comment Share on other sites More sharing options...
