RobPattonDotCom Posted March 28 Share Posted March 28 I have one working as D1 and D2, but I cant seem to sort out what the 8 dipswitches do, fully. It seems 5 changes the amdek to D2, but thats about all I can tell. Does anyone have a scan of the orig manual, or a list of what does what?!? Thanks! Rob Quote Link to comment Share on other sites More sharing options...
+kheller2 Posted March 28 Share Posted March 28 PC version manual is here, I'm not sure if the dip switches would be any different for Atari https://archive.org/details/amdisk-iii-3-inch-disk-drive-users-manual/page/14/mode/2up Or here: https://www.atarimagazines.com/compute/issue46/040_1_REVIEWS_AMDC_3-Inch_Disk_Drives_For_Atari.php " Switches 1 through 4 are density selection switches that allow you to configure the drives for either single or double density on boot-up. The density of the boot drive is determined by the disk installed at boot-up. These switches have no effect if the controller is set for DOS 3.0. Switches 5 and 6 determine which drive will be the boot drive. The factory setting is for drive 1, but any drive up to and including 4 may be selected for this function. Switch 7 is used when more than three drives are connected to the controller, and is particularly useful when there is a 5¼-inch drive attached. When this switch is on, the external drive will be recognized as drive 1. When it is off, the 3-inch drives are 1 and 2, and the external drive is drive 3. Switch 8 sets drives that have been selected as dual density to 256 bytes per sector when off. When switch 8 is on, it sets all drives to be Atari 1050 compatible for use with DOS 3.0. When switch 1 is on, disks with 256 bytes per sector will not be recognized." 1 Quote Link to comment Share on other sites More sharing options...
RobPattonDotCom Posted March 29 Author Share Posted March 29 Awesome, thanks for that find. I wish the docs would expand on what "Switches 1 through 4 are density selection switches that allow you to configure the drives for either single or double density on boot-up" means. I know that all the switches up let me boot a disk I've made with mydos on it, and if I change any of the first 4, it no longer boots. But thats about it. Quote Link to comment Share on other sites More sharing options...
RobPattonDotCom Posted March 29 Author Share Posted March 29 I guess I just sorted it out 1-4 are SD or DD for the first 4 drives (I guess) But I'm still not exactly sure how 5-8 work. Guess I'll keep at it. Quote Link to comment Share on other sites More sharing options...
