Spanner Posted March 29 Share Posted March 29 Idea: You have added Favorites now to the carousel, why not allow users to add save games from the USB Media Select as a favourite so they appear on the carousel, that way you can add what games you like by saving it then can add it as a favourite and the carousel would get some TLC then and you are only adding the games from the USB Media Select, you could use the pngs it makes from the screenshot saves and name it the same as the disk/cartridge so its named the same then you could add the save it makes as a favourites, highlight a save and press a button to add it as a favourite on the carousel, you could use the same button you use to add a favourite, and if you remove the USB then the game will disappear from the carousel but only because its saved on the USB Drive, but if you plug it back in then they should appear again on the carousel, just thought of this. Not a bad idea... 🙂 You need more games on the carousel to use favourites properly and this is one way of doing it. 1 Quote Link to comment Share on other sites More sharing options...
