paulwgraber Posted April 1 Share Posted April 1 I was going to use the channel selector hole on the bottom of the case to put the power mod outlet. Can I remove the channel selector from the board since I am using the av mod? Quote Link to comment Share on other sites More sharing options...
+-^CrossBow^- Posted April 1 Share Posted April 1 8 minutes ago, paulwgraber said: I was going to use the channel selector hole on the bottom of the case to put the power mod outlet. Can I remove the channel selector from the board since I am using the av mod? As long as you don't plan to use the RF anymore, go for it. But if you do, then I would suggest that you jumper it so that it is stuck on channel 3 or 4...whichever works for your needs. Quote Link to comment Share on other sites More sharing options...
paulwgraber Posted April 1 Author Share Posted April 1 If I dont ever plan on using RF do I need to even jump it? Quote Link to comment Share on other sites More sharing options...
+x=usr(1536) Posted April 1 Share Posted April 1 12 hours ago, -^CrossBow^- said: As long as you don't plan to use the RF anymore, go for it. But if you do, then I would suggest that you jumper it so that it is stuck on channel 3 or 4...whichever works for your needs. IIRC, the RF modulator will default to channel 3 with the switch removed. It's been some time since I last had to test that, though, so may be misremembering. 10 hours ago, paulwgraber said: If I dont ever plan on using RF do I need to even jump it? Nope Quote Link to comment Share on other sites More sharing options...
paulwgraber Posted April 1 Author Share Posted April 1 You have been extremely. helpful. Thank you so much. Quote Link to comment Share on other sites More sharing options...
