Celotine Posted April 1 Share Posted April 1 Got a new C64 and had to replace a marginal PLA. I did so with a modern reproduction not an original part. Everything seems to be cool now.. Except I can't seem to load games. Games either don't load or crash almost immediately. I'm using a disk drive emulator, not an original. I have a diagnostic/dead test cart. Dead test passes every time, diagnostic cart fails on ram test 1, freezes and doesn't finish. Ideas on what to do next? Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted April 1 Share Posted April 1 8 hours ago, Celotine said: diagnostic cart fails on ram test 1, freezes and doesn't finish. Ideas on what to do next? Before getting to this part, I was thinking memory. When the computer comes up, do you see the full amount of memory available in the BASIC header? I am assuming, since you replaced the PLA, this is not a short-board 64C model. It would be good to have a 64kx1 RAM chip (4164) to piggy-back onto RAM chips on the board, then run the RAM test. It is likely to have a single RAM chip be flakey, less likely, though not impossible, for multiple chips to be bad. Generally, piggy-backing a good RAM chip works. Quote Link to comment Share on other sites More sharing options...
Celotine Posted April 1 Author Share Posted April 1 6 minutes ago, OLD CS1 said: Before getting to this part, I was thinking memory. When the computer comes up, do you see the full amount of memory available in the BASIC header? I am assuming, since you replaced the PLA, this is not a short-board 64C model. It would be good to have a 64kx1 RAM chip (4164) to piggy-back onto RAM chips on the board, then run the RAM test. It is likely to have a single RAM chip be flakey, less likely, though not impossible, for multiple chips to be bad. Generally, piggy-backing a good RAM chip works. Ok I'll order some up soon. Need parts for my 5200 too. None of my ICs are socketed, I'm glad the piggyback thing works lol. Quote Link to comment Share on other sites More sharing options...
