neuling Posted April 8 Share Posted April 8 Hi good afternoon. I only want the bin data from the program, without headers. how does that work please: mads test.a65 .... ? no header. with header FF FF 00 00 06 00 A9 2D 18 20 5F FF 60 no header: A9 2D 18 20 5F FF 60 Thanks. greeting Quote Link to comment Share on other sites More sharing options...
tebe Posted April 8 Share Posted April 8 opt h- Quote Link to comment Share on other sites More sharing options...
neuling Posted April 9 Author Share Posted April 9 Too bad mads can't do that without a header. greeting 2 Quote Link to comment Share on other sites More sharing options...
drunkeneye Posted April 9 Share Posted April 9 technically, you could just use command line tools, like $ dd if=main.xex bs=1 skip=10 > main.bin at least if you are using linux or something alike. just in case, a .xex can have multiple "parts", and only removing the header might not cut it. Quote Link to comment Share on other sites More sharing options...
mono Posted April 9 Share Posted April 9 @neuling: h- may be insufficient if you need the continuous memory area. Take a look at f+ opt switch and b- if your (cartridge) memory is banked (rmb/nmb/lmb directives and =label as well as :label references are helpful for such model). Quote Link to comment Share on other sites More sharing options...
