hueyjones70 Posted April 13 Share Posted April 13 I have an 800XL that has no audio except for key clicks. I may have caused the problem because I did the SuperVideo 2.1 upgrade. After I finished the upgrade and tested it, I first thought it wasn't booting properly because I wasn't hearing the sound that usually occurs when it boots. I saw the ready prompt but I thought something was wrong in the boot process. After more troubleshooting, I determined that the boot was OK and I just didn't have audio. I tried a different POKEY and that wasn't the problem. Which components provide audio? Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted April 13 Share Posted April 13 (edited) Pin 37 from Pokey to this circuit (SOUND input). The keyboard click comes from GTIA pin 15 and is the BELL input to the audio circuit. Edited April 13 by TGB1718 3 Quote Link to comment Share on other sites More sharing options...
hueyjones70 Posted April 17 Author Share Posted April 17 (edited) I hope someone can explain this to me. When I connected the keyboard the audio returned. I disconnected the keyboard and the audio stayed. Edited April 17 by hueyjones70 Misspelling Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted April 17 Share Posted April 17 Intermittent connection in the area, PCB flexed during insertion, stayed connected when pulled. 1 Quote Link to comment Share on other sites More sharing options...
hueyjones70 Posted April 17 Author Share Posted April 17 (edited) OK I need to try flexing the PCB. Edited April 17 by hueyjones70 Misspelling Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted April 17 Share Posted April 17 (edited) NOOOOOOO. You should not purposely flex PCB, you can break connections, traces, and loosen failing or unseen things, possibly upset a weak swipe even (as seen on 1200XLs) best to take readings while working, write them down. If it fails again, you can compare readings and find what changed. Edited April 17 by _The Doctor__ Quote Link to comment Share on other sites More sharing options...
