+9640News Posted April 21 Share Posted April 21 The attached zip includes the latest version of MDOS, Version 7.45 and a host of various utility updates for MDOS. Enjoy! MDOS745DIS.zip 3 6 Quote Link to comment Share on other sites More sharing options...
+9640News Posted April 21 Author Share Posted April 21 Source code for MDOS has been updated on BeeryMiller/MDOS: MDOS Operating System for Geneve 9640 (github.com) 7 Quote Link to comment Share on other sites More sharing options...
+mizapf Posted April 25 Share Posted April 25 Here are two hard disk images with the GeneveOS 7.45 distribution for use with MAME and TIImageTool, one as a SCSI disk, the other as a MFM disk (HFDC). Not included are the PDF files and the EPROM binaries. (Retracted, possibly having errors) 2 Quote Link to comment Share on other sites More sharing options...
+InsaneMultitasker Posted April 26 Share Posted April 26 @9640News the latest LOAD-SCS needs to be updated. The loader address has not been patched from >2000 to >A000. It appears that the IDE and SCSI versions in the 7.45 ZIP have the same issue. The TIPI and MFM loaders are OK. On 4/21/2024 at 5:21 PM, 9640News said: Source code for MDOS has been updated on BeeryMiller/MDOS: MDOS Operating System for Geneve 9640 (github.com) Are the current loader sources posted in a repository? I wrote a patch program for the build process that will take care of the need to manually edit the start address. 2 Quote Link to comment Share on other sites More sharing options...
+9640News Posted April 27 Author Share Posted April 27 I will need to send you an update Saturday. Quote Link to comment Share on other sites More sharing options...
JJB Posted Wednesday at 10:36 PM Share Posted Wednesday at 10:36 PM On 4/22/2024 at 10:21 AM, 9640News said: Source code for MDOS has been updated on BeeryMiller/MDOS: MDOS Operating System for Geneve 9640 (github.com) Noob question here: is there an easy way to copy the source tree to a HD image? I have tried with the excellent TIImageTool but with the absence of TIFILES headers it's rather slow and error-prone Quote Link to comment Share on other sites More sharing options...
+mizapf Posted Wednesday at 11:05 PM Share Posted Wednesday at 11:05 PM It may sound a bit convoluted, but as stated in the README, copy these files into a TIPI drive. You will then be able to use some file manager inside the emulation to copy them to the HD. If you don't have a TIPI: If you have a spare Raspberry Pi, you can easily set up a TIPI with websocket access that can be used in MAME. 2 Quote Link to comment Share on other sites More sharing options...
+dhe Posted Wednesday at 11:29 PM Share Posted Wednesday at 11:29 PM tl;dr version: Telnet to the tipi, go to the directory you want the files in, should also have the create ti file headers turned on(?) option on the tipi, in that directory, do a git clone of the public repo. Move the source to a drive that is not the tipi. Compile. - tipi's doesn't allow for the creation of large program images like system-sys. as @mizapf said, all this can be done from a pc running mame. Also, no receipts, but I have the sense, your best bet is to copy large things like the mdos source tree with either gdm2k or clint's disk manager (make sure you have the one @InsaneMultitasker updated). Good luck pilot! Quote Link to comment Share on other sites More sharing options...
+9640News Posted yesterday at 12:28 AM Author Share Posted yesterday at 12:28 AM 1 hour ago, JJB said: Noob question here: is there an easy way to copy the source tree to a HD image? I have tried with the excellent TIImageTool but with the absence of TIFILES headers it's rather slow and error-prone I am assuming you do not have a Raspberry PI and/or TIPI? If you have a TIPI, you can setup a native file folder and copy the files to it. Then, when you catalog those files, they will appear as DIS/VAR 80 files. TIDIR has a feature to convert PC files to TIFILES. They should convert very easily over to with it. If you have an issue, give me a shout early Saturday and I will copy the files over as DIS/VAR 80 files and upload a zip with TIFILES headers for all the files. Beery 1 Quote Link to comment Share on other sites More sharing options...
JJB Posted yesterday at 06:39 AM Share Posted yesterday at 06:39 AM Thanks Beery, much appreciated. I'll fire up TI99Dir and give it a go. Quote Link to comment Share on other sites More sharing options...
+mizapf Posted yesterday at 12:15 PM Share Posted yesterday at 12:15 PM You can actually import text files into images in TIImageTool, but you will always be asked whether you intend to import this as a text file. This may be a bit tedious for larger sets of files. BTW, I just found a bug with that function; the imported file does not show up, and when you press F5, it does, but the file system has not been correctly updated. I need to fix that. Edit: Just fixed the import bug; you'll still be asked for the desired import format, though. I'll see how to enhance that for a later version. tiimagetool302.zip 3 1 Quote Link to comment Share on other sites More sharing options...
JJB Posted 17 hours ago Share Posted 17 hours ago Great! I bumped into the import bug and was hoping you would fix it 😁 Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted 17 hours ago Share Posted 17 hours ago Firefox is marking everything I download from this site as having a virus... even before it downloads. WTF...??! 1 Quote Link to comment Share on other sites More sharing options...
+9640News Posted 17 hours ago Author Share Posted 17 hours ago OK, had time to get the source code with the source files with TIFILES headers in D/V80 format. MDOS 745 SOURCE.zip 1 2 Quote Link to comment Share on other sites More sharing options...
Gary from OPA Posted 16 hours ago Share Posted 16 hours ago (edited) 20 minutes ago, OLD CS1 said: Firefox is marking everything I download from this site as having a virus... even before it downloads. WTF...??! It doesn't like how the URL changes to the cloud cdn and the fact it's zip file. I find it also depends on how the zip was compressed, some are more virus trigger happy than others, like ones made with WinRAR. Edited 16 hours ago by Gary from OPA 1 Quote Link to comment Share on other sites More sharing options...
+mizapf Posted 7 hours ago Share Posted 7 hours ago 12 hours ago, OLD CS1 said: Firefox is marking everything I download from this site as having a virus... even before it downloads. WTF...??! From my site? (Edit: ah no, I did not link to my web server here) 1 Quote Link to comment Share on other sites More sharing options...
atrax27407 Posted 2 hours ago Share Posted 2 hours ago That is usually a "reputation exception" (i.e., few previous downloads of the files). EDGE is less sensitive than most and will usually download the file without any problem. Quote Link to comment Share on other sites More sharing options...
Gary from OPA Posted 1 hour ago Share Posted 1 hour ago 38 minutes ago, atrax27407 said: That is usually a "reputation exception" (i.e., few previous downloads of the files). EDGE is less sensitive than most and will usually download the file without any problem. I also believe Firefox now caches the URL domain for a download that been triggered and afterwards it just automatically says nope. Same domain instant don't allow even if a different file. If you have your Firefox clear cache and all cookies on exit it helps. Quote Link to comment Share on other sites More sharing options...
+mizapf Posted 1 hour ago Share Posted 1 hour ago Some days ago I was suddenly unable to connect to this forum. Whenever I opened the URL, I was redirected to an empty page in the admin subtree, if I remember correctly. I had to clear the browser cache to make it work again (and to re-login in every site I visited). This is somewhat disturbing. 1 Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted 1 hour ago Share Posted 1 hour ago 23 minutes ago, mizapf said: Some days ago I was suddenly unable to connect to this forum. Whenever I opened the URL, I was redirected to an empty page in the admin subtree, if I remember correctly. I had to clear the browser cache to make it work again (and to re-login in every site I visited). This is somewhat disturbing. Chrome or Firefox? I know someone else who had that problem in Chrome, but I did not have the problem in Firefox. Quote Link to comment Share on other sites More sharing options...
+mizapf Posted 48 minutes ago Share Posted 48 minutes ago Firefox Quote Link to comment Share on other sites More sharing options...
