Windless Posted April 25 Share Posted April 25 (edited) Hi, Imagine you have the line counter in y register and the y position of a missile in ram (e.g. missile1_y at $80), what is you favorite code to display a two pixel high missile ? I haven't found a solution I am proud of yet and need to concentrate on other things Edit : I say "favorite" because I do not have need for shorter code nor faster code for now, just wondering what solutions you find interesting / beautiful. Edited April 25 by Windless Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted April 25 Share Posted April 25 I think we would need some more input for giving you a good answer here. E.g. Is it a two or a single line kernel? Do you have the line counter in a register? Does it have space or speed optimized? Or a good compromise of both? ... 1 Quote Link to comment Share on other sites More sharing options...
Windless Posted April 25 Author Share Posted April 25 For my current kernel, it is a one line kernel with Y register as the line counter. The development is very early (just testing an idea) so I don't have any space or speed problem yet, my question for now is rather "is there any code you use/know for this problem that you find elegant ?" Quote Link to comment Share on other sites More sharing options...
DEBRO Posted April 25 Share Posted April 25 (edited) Hmmm…untested and done on the fly. This assumes the stack is pointing to ENAM1. Maybe… tya sec sbc missile1_y and #<~[H_MISSILE - 1] php Similar routine is used in Basketball, Breakout, and/or Video Pinball? Edit…in the original post I forgot to include the sec before the subtraction 🤦🏾♂️ I also wanted to use your variable name. Also, keep in mind this works because H_MISSILE is a power of 2. Edited April 26 by DEBRO 1 Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted April 26 Share Posted April 26 14 hours ago, DEBRO said: Hmmm…untested and done on the fly. This assumes the stack is pointing to ENAM1. Maybe… tya sbc missileVertPos and #<~[H_MISSILE - 1] php Similar routine is used in Basketball, Breakout, and/or Video Pinball? Similar routine in Medieval Mayhem. ; RAM M0yEvenRow ds 1 M1yEvenRow ds 1 BLyEvenRow ds 1 M0yOddRow ds 1 M1yOddRow ds 1 BLyOddRow ds 1 ... ; fireball routine ldx #2 .fireballLoop ... sta M0yEvenRow,x sta M0yOddRow,x and #1 beq .decOdd dec M0yEvenRow,x .byte $2c ; skip dec odd .decOdd dec M0yOddRow,x ... dex bpl .fireballLoop ; end of Vertical Blank - NOTE: cannot use JSR during kernel because of this ldx #ENABL ; 2 11 txs ; 2 13 ; Kernel, even rows cpy BLyEvenRow ; 3 php ; 3 6 cpy M1yEvenRow ; 3 9 php ; 3 12 cpy M0yEvenRow ; 3 15 php ; 3 18 ldx #ENABL ; 2 20 txs ; 2 22 ; Kernel odd rows cpy BLyOddRow ; 3 6 php ; 3 9 cpy M1yOddRow ; 3 12 php ; 3 15 cpy M0yOddRow ; 3 18 php ; 3 21 ldx #ENABL ; 2 24 txs ; 2 27 ; start of Overscan, restore stack pointer ldx #$ff ; init stack pointer so we can use JSR txs 1 1 Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted April 27 Share Posted April 27 This Medieval Mayhem blog entry* has a link to the Atari 2600 Advanced Programming Guide at MiniDig which contains a section on using the PHP trick for the missiles and ball. Lots of other useful info at MiniDig, so be sure to check it out. ============================================================== ============================================================== Showing Missiles/Ball using PHP ============================================================== ============================================================== This trick is originally from Combat and is probably the most efficient way to display the missiles and/or ball. This trick just requires that you don't use the stack during your kernal. Recall that: ENABL = $1F ENAM1 = $1E ENAM0 = $1D In this example I'll show how to use the trick for both missiles. You can easily adapt it for the ball too. To set the trick up, before your kernal save the stack pointer and set the top of the stack to ENAM1+1. tsx ; Transfer stack pointer to X stx SavedStackPointer ; Store it in RAM ldx #ENAM1+1 txs ; Set the top of the stack to ENAM1+1 Now during the kernal you can compare your scanline counter to your missile position register and this will set the zero flag in the processor. Then to enable/disable the missile for that scanline, just push the processor flags onto the stack. The ENAxx registers use bit 1 to enable/disable which corresponds with the zero flag in the processor, so the enable/disable will be automatic. It takes few cycles and doesn't vary the number of cycles depending on the result like branching usually does. ; On each line of your the kernal... cpy MissilePos1 ; Assumes Y is your kernal line counter php cpy MissilePos0 php Then before you do it again, somewhere on each scanline you need to pull off the stack again using two PLA's or PLP's, or you can manually reset the stack pointer with ldx #ENAM1+1, txs. After your kernal, restore the stack pointer: ldx SavedStackPointer txs * The comments in that blog entry cover how the PHP trick was expanded with the even/odd lines logic in order to double the height of the missiles and ball. 1 Quote Link to comment Share on other sites More sharing options...
Windless Posted April 27 Author Share Posted April 27 Thank you, This forum is amazing 1 Quote Link to comment Share on other sites More sharing options...
