Are Sram IC and CP1610 CPU interchangeable (PAL/NTSC) ?
Yes, the RA-3-9600 SRAM and CP1610 CPU are interchangeable between PAL and NTSC variants.
Interesting note - the STIC chips are pin compatible and can be safely swapped over, but will yield odd results if you don't make other changes to the system, eg to system clock. You can use an NTSC STIC in a PAL console if you change the system clock crystal (PAL systems have a system clock crystal and a colour frequency crystal) and generate a PAL 60Hz output.
- HZ
Edited by HunterZero
