Tursi Posted April 27 Share Posted April 27 (edited) I ran into this recently and spent some time investigating it... basically, if a key on a keyboard column shared with the joystick is pressed, the joystick axis does not respond (only the key is read). Basically, this means that: - FCTN,1,2,3,4,5 - and Alpha Lock - will disable UP - 6,7,8,9,0 will disable DOWN - Enter,O,I,U,Y,P will disable RIGHT - Space,L,K,J,H,; will disable LEFT and =,comma,period,M,N,/ will disable FIRE As far as I can work out, this is because the keyboard lines are directly connected to the 9901, but the joystick lines run through protection diodes. So if a key is pressed it's basically going to sink all the current rather than pushing through the diode. Since it's hardware, you can see it regardless of the software. I was able to reproduce it in TI BASIC as well as my own software. Any game should show it too, doesn't matter if it means to read the keyboard or not. I was trying to use the joystick as a modifier for keypresses, copying code I used on the ColecoVision, and it took a while to figure out why UP+1 wasn't working... I'll add that discovery to Classic99 as well so it doesn't trip me up in the future, but I thought I'd share it in case the others didn't already know! Edited April 27 by Tursi 5 1 Quote Link to comment Share on other sites More sharing options...
Gary from OPA Posted April 27 Share Posted April 27 (edited) It would be nice someday to restore the joystick back to how it was originally going to be with variable degrees when ti was working on the keypad round wheel via rf or ir transmitter/receiver with the values being returned from +16 to -16 instead of just fixed at +4 and -4 and 4 player option Edited April 27 by Gary from OPA 3 Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted April 27 Share Posted April 27 29 minutes ago, Gary from OPA said: It would be nice someday to restore the joystick back to how it was originally going to be with variable degrees when ti was working on the keypad round wheel via rf or ir transmitter/receiver with the values being returned from +16 to -16 instead of just fixed at +4 and -4 and 4 player option Considering how poorly variable joysticks were implemented at the time (self-centering, my ass,) I am happy for what we got. Quote Link to comment Share on other sites More sharing options...
Tursi Posted April 27 Author Share Posted April 27 39 minutes ago, Gary from OPA said: It would be nice someday to restore the joystick back to how it was originally going to be with variable degrees when ti was working on the keypad round wheel via rf or ir transmitter/receiver with the values being returned from +16 to -16 instead of just fixed at +4 and -4 and 4 player option I think that's the first proper pic I've seen of it... nice. 1 1 Quote Link to comment Share on other sites More sharing options...
+mizapf Posted April 27 Share Posted April 27 9 hours ago, Tursi said: I ran into this recently and spent some time investigating it... basically, if a key on a keyboard column shared with the joystick is pressed, the joystick axis does not respond (only the key is read). Yes, I also expected that when I learned why this AlphaLock / Joystick-up problem occurs. So you tested it on real hardware? I'd like to add that to the TI emulation in MAME, but I cannot test for myself. 1 Quote Link to comment Share on other sites More sharing options...
Tursi Posted April 27 Author Share Posted April 27 2 hours ago, mizapf said: Yes, I also expected that when I learned why this AlphaLock / Joystick-up problem occurs. So you tested it on real hardware? I'd like to add that to the TI emulation in MAME, but I cannot test for myself. Yeah, it makes perfect sense now that I know what it is. I tested every combination on hardware here last night, using several pieces of software to make sure it wasn't just software. 1 Quote Link to comment Share on other sites More sharing options...
Tursi Posted April 27 Author Share Posted April 27 I don't know if the joystick circuit is different on the QI... but I reckon if the Alpha Lock issue still exists there, this likely holds true. Quote Link to comment Share on other sites More sharing options...
Gary from OPA Posted April 27 Share Posted April 27 36 minutes ago, Tursi said: I don't know if the joystick circuit is different on the QI... but I reckon if the Alpha Lock issue still exists there, this likely holds true. I have a QI and somewhere in my junk drawer I have a pair of original ti joysticks. Send me a simple test program and I can try it out. 1 Quote Link to comment Share on other sites More sharing options...
Asmusr Posted April 27 Share Posted April 27 If you use original TI joysticks you would need 3 hands in order to press a key on the keyboard at the same time. 🙂 1 Quote Link to comment Share on other sites More sharing options...
Tursi Posted April 27 Author Share Posted April 27 1 hour ago, Gary from OPA said: I have a QI and somewhere in my junk drawer I have a pair of original ti joysticks. Send me a simple test program and I can try it out. Don't need to! Load any software, or run something in TI BASIC. It's hardware, so the joystick will cut out when you press one of the related keys. 10 CALL KEY(0,K,S) 20 CALL JOYST(1,X,Y) 30 PRINT K;X;Y 40 GOTO 10 Quote Link to comment Share on other sites More sharing options...
PeteE Posted April 27 Share Posted April 27 Does this apply to both joysticks? Quote Link to comment Share on other sites More sharing options...
Tursi Posted April 27 Author Share Posted April 27 1 hour ago, PeteE said: Does this apply to both joysticks? Yes, they run through the same return lines. 1 1 Quote Link to comment Share on other sites More sharing options...
jrhodes Posted April 27 Share Posted April 27 I'm guessing MBX joysticks would also be effected too? Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted April 27 Share Posted April 27 1 hour ago, jrhodes said: I'm guessing MBX joysticks would also be effected too? This probably has implications on the MBX communicating with the TI on the whole, since it uses the joystick port for data. 2 Quote Link to comment Share on other sites More sharing options...
Tursi Posted April 28 Author Share Posted April 28 I'd agree with OLD CS1, but I've no idea what the implications are. Quote Link to comment Share on other sites More sharing options...
+FALCOR4 Posted April 28 Share Posted April 28 Let me see if I can get this link to work. This might be useful to you, KeyBits lets you see the keyboard/joystick interactions directly: Sometimes you may want to scan a key or two directly from the keyboard in your software rather than going through the TI KSCAN routine. This routine, that loads into cartridge ROM, is a quick and easy way to identify the key column and row that you can use for directly addressing the TMS9901. Also see Thierry's page on the TI keyboard implementation for a good rundown on how it works. Just another tool in the tool set. And, yes, the columns are listed vertically and the rows are listed horizontally ? KBCART.bin1.49 kB · 65 downloads KEYBITs.pdf555.88 kB · 73 downloads 2 Quote Link to comment Share on other sites More sharing options...
Tursi Posted April 28 Author Share Posted April 28 Cute tool! Would have been nice when I was building Classic99. These days if I'm checking one key I don't generally store all 8 bits anymore. It's harder to track which bit to set, but since you usually need to change R12 anyway, you can go direct to the bit you want and save a few cycles. (Very few, true, but still ) Quote Link to comment Share on other sites More sharing options...
+FALCOR4 Posted April 29 Share Posted April 29 I used a simpler version of it BITD to sort out some three-keypress sequences that were misbehaving. It's also interesting to see some of the differences between the old console and the QI; especially when it comes to the joysticks. Quote Link to comment Share on other sites More sharing options...
