+David Duer Posted April 29 Share Posted April 29 I went through some Coleco controllers I had gotten years ago and found a modded one with a toggle switch, side button, & 9V battery connection. Anyone have an idea what it is? See photo. Thanks. Quote Link to comment Share on other sites More sharing options...
Pixelboy Posted April 29 Share Posted April 29 Does the toggle switch have three different resting positions (left, center, right)? If yes, then the switch is probably a homebrew add-on to implement the Super Action Controller spinner, which used to be included on the early prototypes of the stock ColecoVision controller. Otherwise, I don't know. Quote Link to comment Share on other sites More sharing options...
+David Duer Posted April 29 Author Share Posted April 29 It does have 3 settings. I didn't understand the 9V battery - and what the side button was for. I'll need to find out if it's still usable. It does work. My Telegames friend thought it could be a rapid fire option, but that didn't work. This makes sense. Thanks. Quote Link to comment Share on other sites More sharing options...
Pixelboy Posted April 29 Share Posted April 29 With a 9V battery and an extra side button, you could perhaps implement Coleco's steering wheel controller. You should test this controller with Turbo (with a 9V battery attached, of course). Quote Link to comment Share on other sites More sharing options...
else Posted April 29 Share Posted April 29 It would be pretty neat if Pixelboy is right. Could have possibly been used for early Turbo game development while the driving controller was also in development? Quote Link to comment Share on other sites More sharing options...
+David Duer Posted April 30 Author Share Posted April 30 I stand corrected now. The toggle switch is stationary and only clicks to right and left, returning to the center. When I tested it on Donkey Kong, it turned off the keypad when switched one way and turned on the keypad the other way. Seems like a switch, not a toggle. I was thinking of opening it up but wanted to see if there were other ideas. It is very nicely made so somebody took time to do it right. I appreciate Pixelboy's idea but I jumped too soon. REALLY want to figure this out. Thanks. Quote Link to comment Share on other sites More sharing options...
+David Duer Posted April 30 Author Share Posted April 30 One more thing - tried to play roller controller game and it did not work. Quote Link to comment Share on other sites More sharing options...
+David Duer Posted April 30 Author Share Posted April 30 Tested Pixelboy's idea with Turbo. Did not work. The mystery continues. Quote Link to comment Share on other sites More sharing options...
+David Duer Posted April 30 Author Share Posted April 30 I decided to open it. See photos. Quote Link to comment Share on other sites More sharing options...
nick3092 Posted April 30 Share Posted April 30 A better picture of the IC markings might help someone figure it out. I can make out a cd4069 hex inverter on the right. Possibly a 4013 flip flop in the middle. Can't make out any markings on the left IC. I do see some wires running to the spot on the PCB where reed switches were planned on being mounted for a spinner in a prototype controller. I'm pretty sure Coleco kept the prototype PCB design, and just used it without reed switches for early production controllers. Quote Link to comment Share on other sites More sharing options...
+David Duer Posted May 1 Author Share Posted May 1 The IC markings: Right - CD4069 Middle - 4013 BPC Left - 4016 BDC Photos attached. Anything more you can add would be great. Thanks. Quote Link to comment Share on other sites More sharing options...
else Posted May 2 Share Posted May 2 (edited) As far as the chips go: 4069 => 2 D Flip-Flops 4013 => 6 Inverters 4063 => 4-Bit Comparator And I'm sure the battery is for powering this circuit. The side button looks like a power switch so that it doesn't drain the battery when not in use, so that one's easy. As for what it actually does, it's still hard to say for certain without a wiring diagram (for me, at least). If I were to guess, I'd say it's an auto-fire circuit for one or both of the buttons. It's designed to count up to a fixed value, "fire", reset the counter, and start again. The center switch selects which button(s) have auto-fire enabled. Just a guess... Edit: It's also possible that the center switch is for selecting the auto-fire speed (lo/med/hi). Pretty cool whatever it is. Someone put some time and thought into it, getting it to fit in the case, etc. I love all these home-made mods from the olden days. Edit 2: Have you tried holding in the side buttons to see if auto-fires then? It may only auto-fire when the button(s) are pushed. Edited May 2 by else Additional comments Quote Link to comment Share on other sites More sharing options...
