macsonny Posted May 5 Share Posted May 5 Hi All, I want to make a SF314 to Atari ST cable (or two). I've printed the 3D connector and shell out to make up mu own cable but I can't seem to find the pinout for the cable. As the cable will go either way I'm assuming it's virtually a pass through cable. Anyone have the exact pinout so I can make my own cable? T^hanks macsonny Quote Link to comment Share on other sites More sharing options...
Chri O. Posted May 5 Share Posted May 5 Atari ST Interfaces & Connectors FD Connector - DIN 14 Female Pin Signal Name 1 Read Data 2 Side 0 Select 3 Logic Ground 4 Index Pulse 5 Drive X Select 6 Drive Y Select 7 Logic Ground 8 Motor On 9 Direction In 10 Step 11 Write Data 12 Write Gate 13 Track 00 14 Write Protect Quote Link to comment Share on other sites More sharing options...
macsonny Posted May 5 Author Share Posted May 5 6 hours ago, Chri O. said: Atari ST Interfaces & Connectors FD Connector - DIN 14 Female Pin Signal Name 1 Read Data 2 Side 0 Select 3 Logic Ground 4 Index Pulse 5 Drive X Select 6 Drive Y Select 7 Logic Ground 8 Motor On 9 Direction In 10 Step 11 Write Data 12 Write Gate 13 Track 00 14 Write Protect Thanks! So it it PIN 1 - PIN 1 PIN 2 - PIN 2 PIN 3 - PIN 3 etc? Quote Link to comment Share on other sites More sharing options...
TZJB Posted May 5 Share Posted May 5 23 minutes ago, macsonny said: Thanks! So it it PIN 1 - PIN 1 PIN 2 - PIN 2 PIN 3 - PIN 3 etc? Yes it should be a straight cable with no crossovers. You need one with a Discovery Cartridge too. Quote Link to comment Share on other sites More sharing options...
macsonny Posted May 5 Author Share Posted May 5 9 minutes ago, TZJB said: Yes it should be a straight cable with no crossovers. You need one with a Discovery Cartridge too. What do you mean "Discovery Cartridge"? Quote Link to comment Share on other sites More sharing options...
TZJB Posted May 5 Share Posted May 5 13 minutes ago, macsonny said: What do you mean "Discovery Cartridge"? Happy Computing moved on from the Atari 8 bit and made an Atari ST cartridge that would flux copy most SSDD and DSDD floppy disks. https://en.wikipedia.org/wiki/Happy_drives It needs a straight cable and I think it came with one. I have one in my garage somewhere as I now use Greaseweazle when necessary. Quote Link to comment Share on other sites More sharing options...
snarkdluG Posted May 5 Share Posted May 5 https://docs.dev-docs.org/htm/search.php?find=Sf314 Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted May 5 Share Posted May 5 This is my go to site for all interface information:- https://info-coach.fr/atari/hardware/interfaces.php Quote Link to comment Share on other sites More sharing options...
351cougar Posted May 7 Share Posted May 7 as far as i can tell falcon didnt have an external 2nd floppy port? also How did the megaSTE do external 1.4mb drives, the HD select isnt plumbed thru that cable. Quote Link to comment Share on other sites More sharing options...
Chri O. Posted May 7 Share Posted May 7 NOTE: I did not test this yet I am assuming TOS4.4 has support for this. On Falcon there is no external floppy port but there is possibility of connecting second floppy internally and wiring the one missing gpio pin from Yamaha sound chip. Quote Link to comment Share on other sites More sharing options...
Chri O. Posted May 7 Share Posted May 7 Back in the day om my Mega ST modified with Atari AJAX(8,16Mhz) chip high density floppy drives (One internal and One external) I needed to provide extra wire to it through a small 3mm jack. Quote Link to comment Share on other sites More sharing options...
