astroguy Posted May 7 Share Posted May 7 I wasn't able to find anything related to using a modded GBS8200 with a composite modded 7800, so I figured I'd provide a description of my experience. Originally I was using one of those AV2HDMI converters but I was really dissatisfied with the processing of 280p as 480i. Purchasing something like a RetroTink is just too expensive. After Canadian customs, shipping and exchange rates the 2X Pro is more that $200 CAD. So after a bit of shopping around I found an 'OSSC Add-on board' on Amazon that transcodes composite to component with the option of line-doubling to 480p for about $35CAD with next-day shipping. This solution alone worked great for my Television which as component in. However, I want to use the 7800 with my desktop monitor, so I picked up a GBS8200 for about $30 CAD and modded it following the GBS-Control guide. I did not bother with the external clock. This gives a nice solution to output resolutions that work with my monitor: 720x480 or 1920x1080. My monitor is 1440p, so I'm using 720x480 with the scaler on the GBS-C tuned to give an integer scaled 6x image. I gotta, say for composite the picture looks very nice and I enjoying the composite blending with games like Rikki&Vikki. The whole package costs me less than $70CAD, which is significantly less than the cheapest RetroTink and is giving me a better picture than the 2x Pro. I've only run into 2 games that gives me trouble: Asteroids for the 2600 and the cut scenes for PacMan 8K. Asteroids will very briefly lose sync semi-periodically which is annoying and it's only the title and cut-scene from 8K that are lost, so I think I can live with the results. That's my experience so far, and maybe someone else will find this useful. 1 Quote Link to comment Share on other sites More sharing options...
harmonyFM Posted May 7 Share Posted May 7 Can you link the Amazon listing(s) for the materials you used? This could be a fun project to follow your lead on. Quote Link to comment Share on other sites More sharing options...
astroguy Posted May 7 Author Share Posted May 7 8 hours ago, harmonyFM said: Can you link the Amazon listing(s) for the materials you used? This could be a fun project to follow your lead on. https://www.amazon.ca/dp/B078ZDTLBJ GBS-8200 https://www.amazon.ca/dp/B0BSDQWVDB OSSC Addon. The prices on both have gone up since my purchases, especially the OSSC Addon, but I'm sure with a bit of searching another low-cost supplier can be found. I followed the GBS-Control Guide: ( https://ramapcsx2.github.io/gbs-control/ ). 1 Quote Link to comment Share on other sites More sharing options...
