Gary from OPA Posted May 8 Share Posted May 8 Saturday Night Bingo by 9T9 Assembly Sig Here is another great sample of TMS9900 Assembly Source Code, this was originally a disk release program by Texas Instruments in Extended Basic in 1980, and has been converted to Assembly most likely around year 1989 by the 9T9 Assembly Sig and Cecil G. Chin and now I have released it with permission to my O.P.A. GitHub and here on AtariAge as usual, and is a good example on how to use RND numbers, the PRINT device, SPEECH and VDP Sprites in Assembly. Enjoy! -=(GaryOPA)=- ************************************************* * SAT-N-BINGO v1.00.80.TIXB by 9T9 Assembly Sig * * * * Saturday Night Bingo * * * * (c)1980 By TI & Cecil Chin & 9T9 Assembly SIG * * * * Released on: May 8st, 2024 by Gary Bowser * * Uploaded to: TI99.AtariAge.com via GaryOPA * * Mirrored to: gary99opa GitHub Repositories * * * * BINGO-S -> The Assemble Source Code File * * BINGO-MNE -> Saturday Night Bingo Assembly * * BINGO-SUB -> Commonly Used BLWP/BL Library * * BINGO-TXT -> Text Block after the DataArea * * * ************************************************* GITHub Release Link: https://github.com/gary99opa/sat-n-bingo SATNBINGO-Source-Files-Only.zip SATNBINGO.dsk SATNBINGO_1_00_80_TIXB_GaryOPA_05_08_2024.zip 4 3 Quote Link to comment Share on other sites More sharing options...
WhataKowinkydink Posted May 8 Share Posted May 8 Classic 1 Quote Link to comment Share on other sites More sharing options...
RickyDean Posted May 8 Share Posted May 8 Seems that there is an issue with Atariage this morning, some forum links I click on and I get a 404 erro, then after some time I try again and the links work. Also trying to DL the above files, I get Sorry! We could not locate the item you are trying to view. Contact Us Quote Link to comment Share on other sites More sharing options...
Gary from OPA Posted May 8 Author Share Posted May 8 (edited) 15 minutes ago, RickyDean said: Seems that there is an issue with Atariage this morning, some forum links I click on and I get a 404 erro, then after some time I try again and the links work. Also trying to DL the above files, I get Sorry! We could not locate the item you are trying to view. Contact Us That seems to occur with my other releases as well. Hopefully they fix it. You can find the files on my GitHub and on my Patreon pages. Just check no files download at all even in other threads here. Hopefully @Albert can fix this issue. Edited May 8 by Gary from OPA no attachments are working Quote Link to comment Share on other sites More sharing options...
Albert Posted May 8 Share Posted May 8 I will investigate. ..Al 1 2 Quote Link to comment Share on other sites More sharing options...
Gary from OPA Posted May 8 Author Share Posted May 8 1 hour ago, Albert said: I will investigate. ..Al Looks like downloads are working again. Many thanks for your quick response and service. Hopefully the rest of your week goes smoothly. 1 Quote Link to comment Share on other sites More sharing options...
