CV Basic: scrolling
Can I do a horizontal scroll in CV Basic? Nothing fancy, just moving the screen left and repeating the pixels over and over again. I can't find anything in the manual about how to scroll. In INTY Basic, there is a SCROLL function. Is there anything similar here?
It's like trying to do smooth scaling on the Sega Genesis... you just can't do it. But you can fake it! There are games with subtle tricks that will make you THINK you're getting fast, smooth scrolling out of the machine. Imagic's Nova Strike is a great example. Only a small portion of the screen scrolls... most everything else is static, giving you a convincing illusion of movement and a convincing illusion of parallax to boot!
It's all about fooling the eye with these old game systems. What they can't do, you replace with sleight of hand. See also the waterfalls on Sonic 2 for the Genesis, which LOOK for all the world like they're transparent, except they're not... every other pixel of the fall is drawn, giving you the impression on a CRT screen that the waterfall is in fact transparent. Playing the game on a LCD screen pulls the curtain back and reveals how the trick is done, but it still looks pretty sharp regardless.
Posted (edited)
On 5/11/2024 at 8:15 AM, drfloyd said:
is it possible because of the SGM and extra RAM, we agree ?
I've done a small sample for you as well. A bit larger than Nano's one and (I think) without tearing (try the rom in a plain Colecovision and let me know).
If you want to try your own picture follow these steps:
1. Edit ScrollTest.bmp adding your own image in the first 256x192 quarter of the picture (top left) - NOTE the code is scrolling only the lower 256x64 part.
2. Copy the same image in the top right quarter of the picture
3. Copy the first half of the image (512x192) on the lower part of the image with an offset of 4 pixels
4. run tmscolor -z -t -b -o result.bmp ScrollTest.bmp ScrollTest.bas - NOTE1 small errors due to color bleeding could be acceptable, it depends on the case. NOTE2 make sure that the total tile count is <=255
5. copy this code in ScrollTest.bas just after the second DEFINE command, replacing the SCREEN command generated by tmscolor
    ' replace the SCREEN command in the stub generate by TMSCOLOR
	SCREEN image_pattern,0,0,32,24,64
	#X = 0
	WHILE 1
	WAIT
	if (#X and 1) then
		SCREEN image_pattern,#X/2+64*8,256,32,16,64
	else
		SCREEN image_pattern,#X/2+64*8+64*24,256,32,16,64
	end if
	IF CONT.RIGHT THEN #X = (#X + 1) and 63
	IF CONT.LEFT THEN #X = (#X - 1) and 63
	WEND
6. run the compiler by cvbasic ScrollTest.bas output.asm
7. run the assembler gasm80 output.asm -o output.rom
8. run output.rom, use the RIGHT and LEFT to move the screen
Enjoy
ScrollTest.bas output.rom
Edited by artrag
Posted (edited)
The explanation for this technique is this:
All the tiled used for in the scrolling for the different offsets (in the example just 2, but the image works also with 4 offsets), should fit in the tileset (256 tiles)
In the sample used color bleeding occurs in few points, it can be acceptable or not, depends on the cases.
Level design should avoid that the number of tiles passes the limit of 256 and color bleed.
For each offset you need to define a separate level map. Here there are two level maps, one on top of the other, at offset 64*24.
According to the value of the the map coordinate, you choose which level map has to be used has origin of the data to be copied by SCREEN
Advanced technique
Due to the fact we consider only horizontal scrolling, you could have 3 different tile banks of 256 tiles each specialised for the area of the screen to be rendered.
This increases the variety of tiles and tile combinations that can be supported and can be achieved with the simple tool tmscolor.
The solution is to cut the source image with the whole level in 3 stripes of height 64 pixels.
For each of them, generate the offset images as above.  You will end with 3 images (one per bank) with 2 (or 4) offsets each.
Use tmscolor to generate the tile definitions of each bank and DEFINE VRAM PLETTER address,length,label to load the 3 banks in VRAM
For each offset, assemble the data of the 3 PNTs (one per bank) in a single map.
Use SCREEN as above on the assembled map
Edited by artrag
Posted (edited)
The files in attach show the same idea as above, BUT with 4 offsets. The movement is 2 pixels at time, much smoother.
The used tiles are 225, and I've removed the color bleeding manually in the intermediate frames.
As above, the code is very easy:
Quote
    MODE 0
    DEFINE CHAR PLETTER 0,225,image_char
    DEFINE COLOR PLETTER 0,225,image_color
    SCREEN image_pattern,0,0,32,16,64
    #X = 0
    WHILE 1
    WAIT
    SCREEN image_pattern,#X/4+64*8+64*16*((#X) and 3),256,32,16,64
    IF CONT.RIGHT THEN #X = (#X + 1) and 127
    IF CONT.LEFT  THEN #X = (#X - 1) and 127
    WEND
There are 4 level maps stacked in the image_pattern data, each is 64x16 and is representing a given offset
The correct map is chosen according to the offset (#X and 3) at position #X/4
If you want to try your own image, note that the code is scrolling a 256x64 area, so this time I've cropped the first third of the screen in ScrollTest.bmp
1. Edit ScrollTest.bmp adding your own image 256x64 in the first quarter of the picture (top left) - NOTE the code is scrolling only the lower 256x64 part.
3. Copy the first half of the image (512x64) on the lower part of the image 3 times with an offset of 2 pixels
4. run tmscolor -z -t -b -o result.bmp ScrollTest.bmp ScrollTest.bas - NOTE1 small errors due to color bleeding could be acceptable, it depends on the case, edit the image if you do not like them. NOTE2 make sure that the total tile count is <=255
5. copy the code above in ScrollTest.bas just after the second DEFINE command, replacing the SCREEN command generated by tmscolor
Compile, assemble and run
Enjoy!
Edited by artrag
  • 4 months later...
Is there any easy way to shift the characters a direction on the display easily? I was thinking there must be a way to accomplish this quickly using the SCREEN command since it can push ROM or RAM data so quickly to the screen, but I haven't managed to get the command to point to VRAM successfully.   A nested FOR/LOOP to VPOKE adjacent characters works, however it is fairly sluggish.
Well, I want to scroll the screen, but am not concerned about per pixel smooth scrolling.  I'd like to shift all the characters on the screen in one direction, while building a new strip of characters on the edge of the screen, similar to how you'd accomplish scrolling more than 8 pixels on the Intellivision.
The best solution is to copy the whole screen from a larger area in rom. Use SCREEN for that.
You cannot copy the screen on itself one step away and then add a column.
It would take more than one frame and give visible artifacts.
Edited by artrag
If you have enough ram, build the page in ram and move all the 768 tiles in one frame using SCREEN.
The other possibility is use two PNTs in vram. Build the next frame in one table while showing the other one. Once done, swap the two PNTs and continue with the next frame.
Edited by artrag
