Does anyone abuse the RAM mirrors?
I am asking, because one of my 7 units will not present RAM there, it leaves the region unmapped.  Can't be the only one, so if you do, fix it or your homebrew may not work on all machines!
What are you using to test the mirroring on the RAM? I believe @RevEng's 7800 utility cartridge has a mirror test as part of the RAM testing routine?
I mapped my own RAM into that area and wrote my own test and that only works on one motherboard, every other one crashes hard. ;)
Interesting, I've yet to see any 7800 cross my path that failed the RAM test routines in the utility cart but then I'm sure it is possible to do some funky stuff to stress it all more. The only real issue with any homebrew I've been a part of, was do to a few Rockwell CPU based 7800s not liking the games and crashing within a few min of playing or exhibiting quite a bit of graphical corruption on the screen (During DLI I think?). In those instances, I've advised my clients to let me replace the CPUs with a different brand. Usually Signetics or NCR when I can.
But the RAM I've never found I've had to replace although as you know from a previous posts, there was as lot of different brands and spec RAM used in the 7800 throughout the production cycles with other components changes being done on the fly to work with them.
I don't think it has to do with the RAM at all, it is what selects the individual CS lines on the RAM chips.  Usually mirrors exist, because people cut corners on address line detection (to save pins and parts, especially back then).  I think this board actually pays proper attention to the region for some reason, I have no time to trace the whole thing but I am sure another one exists.
6 hours ago, Eagle said:
I think you misunderstood, I am talking about the region of memory below $4000.  I have done some crazy RAM bankswitching as well, but the goal is a bigger footprint of RAM.
Wow, I am socketing one of my boards and I just came across the weirdest RAM modification.  How does this even work?  Maybe I am just tired, but pulling WE into a permanent state doesn't make sense to me, maybe the other end of the resistor isn't GND or VCC?  I have to look at the trace, maybe this is the board that allows the extra RAM mapping (I forgot which one it is).
3 hours ago, CPUWIZ said:
Never mind, they only dampen the WE line, not sure why.
I've seen that factory modification done on many many 7800s. I believe it is present on most that have RAM faster than 150ns in use like the one you've shown that appears to be 100ns speed?
It is mostly Sony brand chips I see they have done this too, but I've found it on others as well but it tends to be mostly the Sony RAM that gets this factory modification. I actually desolder the lead from the resistor to the IC leg and apply shrink tubing over it before attaching it back into place.
2 hours ago, batari said:
I don't think it's normal to be missing the mirrors of $40-$FF/$140-$1FF at $2040-$20FF/$2140-$21FF, and I would suspect a broken console.
I am talking about $2800.
Per the A7800 source, derived from actual hardware testing and analysis from @RevEng and others:
Quote
    AM_RANGE(0x2000, 0x27ff) AM_RAM AM_SHARE("6116_2")
                                // According to the official Software Guide, the RAM at 0x2000 is
                                // repeatedly mirrored up to 0x3fff, but this is evidently incorrect
                                // because the High Score Cartridge maps ROM at 0x3000-0x3fff
                                // Hardware tests show that only the page at 0x2700 appears at
                                // 0x2800, and only on some hardware (MARIA? motherboard?) revisions,
                                // and even then with inconsistent and unreliable results.
The updated Software Guide also denotes the memory map conflict (2800 to 2FFF).
Yes, that is precisely what I am talking about, one of my machines allows $2800-$2FFF to be mapped. 👍
Yeah, I believe that old document from 1998 is simply wrong. I've never found anything solid at $2800 on any console. Some versions of Concerto firmware have used this area, and not a single issue has been found with using $2800-$2FFF after boot. I am not sure why your console presents RAM there, but it's possible it's just weakly driven when the chip selects are not active.
However, you can't just put RAM there until after boot, as I understand this area is used by the BIOS while some of the upper address lines are zeroed out.
Hmm, writing to $2000 is the same as $2800 on several of my RAM tests, maybe I did something wrong back then (it was 10 years ago).   And yeah, I know about the BIOS, I screwed myself up with that.
  • 2 weeks later...
