Transfer .dsk file using a non HDX RS232 card on TI994a
PeteW
I am trying to transfer a .dsk file from a PC to a TI994a through RS232.  I am unable to do it from the information I have gathered from the internet.  It seems you need a RS232 card with a HDX conversion.  Is there anyway of doing this transfer without a RS232 HDX conversion, and with a plain RS232 card?
yes, you need this program on your TI99 itself:
https://hexbus.com/ti99geek/Projects/ti99hdx/ti99hdx_nanopeb.html
It will work with not modified TI RS232 card using a straight thru cable
And then the TI99 HDX server on your PC itself.
https://hexbus.com/ti99geek/Projects/ti99hdx/ti99hdx_server.html#ti99hdx
Download: Dsk2Pc - Copy disk image to and from PC - Version 2.1
here: https://hexbus.com/ti99geek/Projects/dsk2pc/dsk2pc.html
All programs for the different configurations (modified RS232 card, unmodified RS232 card, nanoPeb, CF7+) are in this download.
The program you need for what you want to do is this: "NpDsk2Pc is the nanoPeb version of Dsk2Pc but can also be used on a TI99/4A or Geneve with standard RS232 card".
And on the PC side you need the HDX server program:
Download: Ti99Hdx Server - Version 11.3a
here: https://hexbus.com/ti99geek/Projects/ti99hdx/ti99hdx_server.html
You only need to organize a cable from TI side RS232 DB25 to PC side RS232 DB9.
See also the help file of the server program or the website.
NpDsk2Pc uses RS232/1 !! (because the nanoPeb only has 1 serial port).
Edited by F.G. Kaal
