+Larry Posted Wednesday at 06:17 PM Share Posted Wednesday at 06:17 PM I'm having trouble with a text file that has unusual spacing: T I T L E 1 T I T L E 2 T I T L E 3 (and so on) I want to get the titles in regular text format: TITLE 1 TITLE 2 TITLE 3 I haven't been able to come up with a BASIC subroutine to properly remove the extra spaces. Perhaps you can? Note that there are two spaces between titles, and just one space between letters. Thanks for any ideas. Needn't be elegant; just needs to work. Quote Link to comment Share on other sites More sharing options...
+Stephen Posted Wednesday at 08:22 PM Share Posted Wednesday at 08:22 PM Quick thoughts on this - read two bytes at a time from the file. Stop and check to see if both bytes equal a space character. If they do, "discard" these 2 bytes (ignore them). Read two more bytes and again compare. If they are both spaces, discard, if they are not, write both bytes to either a temp buffer, or the new file you are creating, whatever. Repeat until EOF. 1 Quote Link to comment Share on other sites More sharing options...
Rybags Posted yesterday at 12:19 AM Share Posted yesterday at 12:19 AM I think you'd be best off doing multiple passes on each text line. If you detect a single space but not two then remove it and set a flag. Process each line repeatedly until you don't have flagging. To make it easier you might want to add an extra character such as full-stop to the end of the line then remove it after processing. Single space test would be something like: IF A$(N,N) = " " AND A$(N,N) <> " " THEN ... (second comparison has 2 spaces) 1 1 Quote Link to comment Share on other sites More sharing options...
E474 Posted yesterday at 12:27 AM Share Posted yesterday at 12:27 AM Just strip out all spaces, but if the next character is numeric insert a space. 1 1 Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted 19 hours ago Share Posted 19 hours ago (edited) Here, try this , obviously the machine code bit won't print, so the file SPACES.BAS is attached 10 DIM ML2$(108),A$(50),B$(10) 15 ML2$="hðTÉÐQhÌhËhhhÏhÎhh¨±Îgø©ÔÕ ¢±ËÝgÐàÐèìðÈÌð¸PãÈÌð¸PØ`ªhhÊÐû`¬ÈÔ`Ô`" 20 A$="T I T L E 1 T I T L E 2 T I T L E 3" 30 X=USR(ADR(ML2$),ADR(A$),LEN(A$),ADR(" "),1) 40 IF X THEN A$(X)=A$(X+1):A$=A$(1,LEN(A$)) 50 IF X THEN ? A$:GOTO 30 55 IDX=1 60 X=USR(ADR(ML2$),ADR(A$),LEN(A$),ADR("1"),1) 70 IF X THEN B$=A$(IDX,X):IDX=X+1 80 ? B$ 90 X=USR(ADR(ML2$),ADR(A$),LEN(A$),ADR("2"),1) 100 IF X THEN B$=A$(IDX,X):IDX=X+1 110 ? B$ 120 X=USR(ADR(ML2$),ADR(A$),LEN(A$),ADR("3"),1) 130 IF X THEN B$=A$(IDX,X):IDX=X+1 140 ? B$ Screen Shot of output Should have added, the USR call can find any sub-string in a larger string, it returns the position of the first character of the sub-string in the main string, returns 0 if not found. SPACES.BAS Edited 19 hours ago by TGB1718 1 Quote Link to comment Share on other sites More sharing options...
+Larry Posted 15 hours ago Author Share Posted 15 hours ago Thanks to all for the ideas! I'll try a couple of these things today and tomorrow. I'm a bit under the weather. So if you don't hear back from me promptly, it's not because I've lost interest. My text file is about 10,000 characters in length, and it actually is a file of my DVD collection from originally (I think) a WORD 97 file. I'll read that into a big string and try SPACES.BAS. @TGB1718 -- that looks very promising! I've usually been able to figure out parsing issues like this one in the past, but I've haven't done much programming in the past several years. Quote Link to comment Share on other sites More sharing options...
