Scuttle130 Posted December 10, 2003 Share Posted December 10, 2003 Can anyone figure out what I am doing wrong here? Or does anyone have a way to make this more efficient? ; Ship Version 1.0 ; Subsequent versions will allow additions of capabilities ; A learning objective processor 6502 include "vcs.h" include "macro.h" ; Variables SEG.U variables ORG $80 shipx ds 1 shipy ds 1 visibleship ds 1 shipbuffer ds 2 shipdirection ds 2 SEG variables ; Program ; Clear RAM and TIA Start sei cld ldx $FF txs lda #0 ClearMemory sta 0,x dex bne ClearMemory ; Initialization lda #$00 ; Set backgound color to black sta COLUBK lda #$1C ; Set ship color to yellow sta COLUP0 lda #2 ; Set ship x position sta shipx lda #80 ; Set ship y position sta shipy lda #%0001 ; Set ship facing up sta shipdirection ; VSYNC time Main lda #2 sta VSYNC sta WSYNC sta WSYNC sta WSYNC lda #43 ; Set timer for VSYNC sta TIM64T ; Just another way to do Vertical Blank lda #0 sta VSYNC ; Check joystick controls for movement lda #%00010000 ; Down? bit SWCHA bne SkipMoveDown inc shipy lda #%00001000 ; reflect ship graphics sta REFP0 lda #%0001 sta shipdirection SkipMoveDown lda #%00100000 ; Up? bit SWCHA bne SkipMoveUp dec shipy lda #%00000000 ; do not reflect ship graphics sta REFP0 lda #%0001 sta shipdirection SkipMoveUp lda #%01000000 ; Left? bit SWCHA bne SkipMoveLeft dec shipx lda #%00001000 ; reflect ship graphics sta REFP0 lda #%1000 sta shipdirection SkipMoveLeft lda #%10000000 ; Right? bit SWCHA bne SkipMoveRight inc shipx lda #%00000000 ; do not reflect ship graphics sta REFP0 lda #%1000 sta shipdirection SkipMoveRight lda #0 sta shipbuffer WaitForVBLANKEnd lda INTIM bne WaitForVBLANKEnd ; Visible Screen Drawing ldy #191 sta WSYNC sta VBLANK ; Start to draw screen DrawScreen sta WSYNC lda shipbuffer sta GRP0 ldx shipx ; horizontal sprite check cpx #160 bcc LT160 ldx #0 sta shipx LT160 jsr PositionSprite CheckVisibleShip cpy shipy bne SkipVisibleShip lda #8 sta visibleship SkipVisibleShip lda #0 sta shipbuffer ldx visibleship beq FinishDrawScreen DrawShip lda #%0001 cmp shipdirection bne DrawRightShip lda ShipUp-1,x sta shipbuffer dec visibleship jmp FinishDrawScreen DrawRightShip lda ShipRight-1,x sta shipbuffer dec visibleship FinishDrawScreen dey bne DrawScreen lda #2 sta WSYNC sta VBLANK ldx #30 Overscan sta WSYNC dex bne Overscan jmp Main Divide15 .byte 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00 .byte 01,01,01,01,01,01,01,01,01,01,01,01,01,01,01 .byte 02,02,02,02,02,02,02,02,02,02,02,02,02,02,02 .byte 03,03,03,03,03,03,03,03,03,03,03,03,03,03,03 .byte 04,04,04,04,04,04,04,04,04,04,04,04,04,04,04 .byte 05,05,05,05,05,05,05,05,05,05,05,05,05,05,05 .byte 06,06,06,06,06,06,06,06,06,06,06,06,06,06,06 .byte 07,07,07,07,07,07,07,07,07,07,07,07,07,07,07 ; .byte 08,08,08,08,08,08,08,08,08,08,08,08,08,08,08 ; .byte 09,09,09,09,09,09,09,09,09,09,09,09,09,09,09 ; .byte 10,10,10,10,10,10,10,10,10,10,10,10,10,10,10 ; .byte 11,11,11,11,11,11,11,11,11,11,11,11,11,11,11 ; .byte 12,12,12,12,12,12,12,12,12,12,12,12,12,12,12 ; .byte 13,13,13,13,13,13,13,13,13,13,13,13,13,13,13 ; .byte 14,14,14,14,14,14,14,14,14,14,14,14,14,14,14 ; .byte 15,15,15,15,15,15,15,15,15,15,15,15,15,15,15 ; .byte 16,16,16,16,16,16,16,16,16,16,16,16,16,16,16 ; .byte 17,17,17,17,17,17,17,17,17,17,17,17,17,17,17 ; .byte 18,18,18,18,18,18,18,18,18,18,18,18,18,18,18 PositionSprite sta WSYNC lda Divide15,x tax Loop dex bne Loop sta RESP0 rts ShipUp .byte #$44 ;01000100 .byte #$28 ;00111000 .byte #$FE ;11111110 .byte #$7C ;01111100 .byte #$28 ;00111000 .byte #$10 ;00010000 .byte #$10 ;00010000 .byte #$10 ;00010000 ShipRight .byte #$20 ;00100000 .byte #$B0 ;10110000 .byte #$78 ;01111000 .byte #$7F ;01111111 .byte #$78 ;01111000 .byte #$B0 ;10110000 .byte #$20 ;00100000 .byte #$00 ;00000000 ; Interrupt Vectors ORG $FFFA InterruptVectors .word Start ; NMI .word Start ; Reset .word Start ; IRQ ; DASM execution code: ; dasm {filename}.asm -l{filename}.txt -f3 -v5 -s{filename}.txt -o{filename}.bin ; ; FSB execution code ; fsb {output file}.asm {red file}.bmp {green file}.bmp {blue file}.bmp Quote Link to comment Share on other sites More sharing options...
Cybergoth Posted December 10, 2003 Share Posted December 10, 2003 Hi there! I spot several *substandard* techniques in that source. Joystick reading is done way more efficient and horizontal positioning is done in a few bytes without such a giant table for example. I'd suggest you should subscribe [stella] to improve your programming "Kung Fu" Try browsing the [stella] archive for "Battlezone;positioning" for example. Greetings, Manuel Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted December 10, 2003 Share Posted December 10, 2003 BTW: Please use ... to make your source more readable and formatted as it was. Quote Link to comment Share on other sites More sharing options...
Tom Posted December 10, 2003 Share Posted December 10, 2003 your trying to cram your whole program into the ram. change SEG variables ; Program into something like SEG code org $f000 ; Program after this it displays something that might be a ship, but it's still buggy. your timing is totally screwed up, run it with z26 with the -n switch and you'll see. Quote Link to comment Share on other sites More sharing options...
Cybergoth Posted December 10, 2003 Share Posted December 10, 2003 Hi there! after this it displays something that might be a ship, but it's still buggy. your timing is totally screwed up, run it with z26 with the -n switch and you'll see. Also it will execute only coarse positioning. Greetings, Manuel Quote Link to comment Share on other sites More sharing options...
Scuttle130 Posted December 10, 2003 Author Share Posted December 10, 2003 Thank you! Thank you! Thank you! This stuff can be so frustrating, escpecially to a newbie!!!! Quote Link to comment Share on other sites More sharing options...
