A2600 Posted December 24, 2003 Share Posted December 24, 2003 I have a 4.5GB Seagate Hard Drive, but I dont know if its SCSI or not, what do i need to look to see if its a SCSI or the other type of HD (I??) Im planning to use it with my future MegaSTe or buy the SCSI board to use it with my 1040STf If its not SCSI well its back to the closet with it... and see if I can see a SCSI HD in the Computer Jamboree in Miami, FL (Feb. 04) Quote Link to comment Share on other sites More sharing options...
herr professor Posted December 25, 2003 Share Posted December 25, 2003 You can usually look it up by the model # on the drive if you are not familar with how a scsi connector may look. Quote Link to comment Share on other sites More sharing options...
ussexplorer Posted January 3, 2004 Share Posted January 3, 2004 I asume with the time line of computer and most scsi hard drives if you cannot look it up on the net. SCSI or SCSI 1 is a 50 pin connector IDE is a 40 pin connector. Older scsi drives had two long terminators on the under side of the drive. ALso the scsi will probably have labeled ID1, 2, 3 and the IDE drive will have Master/Slave/CS - Cable Select. If it is a scsi 2 drive or newer models are a completly different connector than one that looks like a IDE 40 pin ribbon cable. Quote Link to comment Share on other sites More sharing options...
Gunstar Posted January 3, 2004 Share Posted January 3, 2004 If and when you start looking for scsi drive adapter, be aware that some of the interface/adapters for scsi are the older MFM style, which don't have a 50 pin connector, although the ribbon has 50 lines, MFM style ribbon connects to the edge of the HD PCB creating a connection not unlike PCI cards inserted into the PC motherboard. Mine is like this. Which confused the hell out of me at first when I was looking for a compatible HD for my adapter, the manuals refered to compatible drives as scsi and never mentioned MFM style at all. Quote Link to comment Share on other sites More sharing options...
ussexplorer Posted January 3, 2004 Share Posted January 3, 2004 Talk about before my time. I had a old, old tape drive that had that type of connector. It looked almost like a regular cassette tape with some extra notches in it. I think it held like 10 megabytes total. The new scsi cards wouldn't even reconize it. laters. Quote Link to comment Share on other sites More sharing options...
Curt Vendel Posted January 4, 2004 Share Posted January 4, 2004 SCSI uses a 50 Pin connector (unless its an Ultra Wide and has a 68pin keyed connector) and IDe uses smaller 34 pin IDE cable. The label on your drive should say SCSI on it, from the sound of it, if it is a Seagate SCSI, it most likely is a Barracuda or Cheetah HD and should say it on the label. Whats the Model # of the drive? Curt Quote Link to comment Share on other sites More sharing options...
lais Posted January 4, 2004 Share Posted January 4, 2004 SCSI uses a 50 Pin connector (unless its an Ultra Wide and has a 68pin keyed connector) and IDe uses smaller 34 pin IDE cable. No, 34-way is for floppy drives. IDE is 40. Quote Link to comment Share on other sites More sharing options...
Curt Vendel Posted January 5, 2004 Share Posted January 5, 2004 SCSI uses a 50 Pin connector (unless its an Ultra Wide and has a 68pin keyed connector) and IDe uses smaller 34 pin IDE cable. No, 34-way is for floppy drives. IDE is 40. Errr uh... oooopsey I did say 34 didn't I??? Yup, it is 40, not 34 and yes 34 is floppy... can you say DUH! Sorry guys :-) Curt Quote Link to comment Share on other sites More sharing options...
A2600 Posted January 5, 2004 Author Share Posted January 5, 2004 SCSI uses a 50 Pin connector (unless its an Ultra Wide and has a 68pin keyed connector) and IDe uses smaller 34 pin IDE cable. The label on your drive should say SCSI on it, from the sound of it, if it is a Seagate SCSI, it most likely is a Barracuda or Cheetah HD and should say it on the label. Whats the Model # of the drive? Curt I can't give that information yet since I dont have the machine YET , but the HD thats going into her its a Seagate I just have to check and see if its a Barra or Chee! Quote Link to comment Share on other sites More sharing options...
