Lord-Chaos Posted January 11, 2004 Share Posted January 11, 2004 I always could format normal DD disks as HD disks on my MEGA STE. Can all ST 1.44 drives format DDs without problems and without data loss? My disks still work after almost 10 years? BTW. Can ST drives format HD disks with more than 20 sectors/track ? Mine does not, but can format 84 tracks. The AMIGA can use 22 tracks and with special tools even more AFAIK (almost 2Mbyte/disk). I used a program called FCOPY Pro to format HD disks up to 20 sectory/84 tracks. This program formats DD disks up to 11 sectors/84 tracks , these are a little bit slower than 720K disks, but I never had serious data loss. Thimo Quote Link to comment Share on other sites More sharing options...
Ayreon Posted January 11, 2004 Share Posted January 11, 2004 If you make an extra hole in the disk all 1.44 drives will see a DD as a HD. Some disks probably work better and are more reliable than others. I can't say i used this method much, but it worked fine for me. Quote Link to comment Share on other sites More sharing options...
Lord-Chaos Posted January 15, 2004 Author Share Posted January 15, 2004 If you make an extra hole in the disk all 1.44 drives will see a DD as a HD.Some disks probably work better and are more reliable than others. I can't say i used this method much, but it worked fine for me. My MEGA STE could format the DD disks as HD disks without the extra hole.And the MEGA STE of a friend could do this, too. Thimo Quote Link to comment Share on other sites More sharing options...
Ayreon Posted January 15, 2004 Share Posted January 15, 2004 strange, but interesting My Falcon doesn't format DD as HD without fooling it with an extra hole. I don't have any experience with the Mega STE so i can't tell wether it is "normal" or not Quote Link to comment Share on other sites More sharing options...
twbrown Posted January 16, 2004 Share Posted January 16, 2004 well i got a Mega and can't format HD floppies..got a Epson smd-300 floppy drive and set the jumper (#7) and still no go...i get the requestor and it has hd listed but when i try to format it says disk is either not in drive or defective...looks like i need an AJAX chip Quote Link to comment Share on other sites More sharing options...
