Tickled_Pink Posted January 14, 2004 Share Posted January 14, 2004 I have some Atari ST CD-ROMS that I'm trying to read in a PC. The drive has problems trying to read them and eventually stops trying. Are they in a different format to normal PC CDs? Quote Link to comment Share on other sites More sharing options...
twbrown Posted January 14, 2004 Share Posted January 14, 2004 well think they are in same formats..I have several cdrom for the atari (suzy b's, crawlys crypt ect) and i can read them fine..to use em tho i copied them to a directory in my steem program..you can see contents on IBM but not run them,or at least i can Quote Link to comment Share on other sites More sharing options...
Mendon Posted January 15, 2004 Share Posted January 15, 2004 Sorry.. mis-read post and left dumb answer.....sigh... Mendon Quote Link to comment Share on other sites More sharing options...
Curt Vendel Posted January 15, 2004 Share Posted January 15, 2004 Its possible that they are not in ISO-9660 format which is the more universally accepted format that works on PC's, ST's, Mac's, Amiga's... You may have a CD that is in Hi-Sierra format and older PC CD-Rom's used to be able to read them, but most newer drives and drivers don't seem to be able to read that older format that never took off... There may be a utility out that can read them, otherwise pick up a null modem cable (Radio Shack still sells null-modem adapters) and download Ghostlink and run the Slave on your PC and the Master Program on your ST, then you can assign a directory on your PC as a drive that you can mount on your ST, then just copy of the contents of the CD over to that mapped drive serial linked on your PC and move it over that way. Curt Quote Link to comment Share on other sites More sharing options...
