Tempest Posted January 31, 2004 Share Posted January 31, 2004 One of the nice things my Falcon has installed on it is something called XBoot III. Unfortunately I have no idea what many of the options do. Can any Flacon-heads out there help me out? The guy I got this from apperently did alot of graphics and 3D modeling, so I assume alot of this stuff is related to that. PRG Menu ------------ BlowBoot - Boot sequence for the blowup device? I tried it with the blowup on and the monitor went wiggy. DESKPIC EXTENDDOS - Extended Dos? FOLDR600 FPATCH1 FPATCH2 GENEVA JAR10 JAR30 JPEGD MINTNP -MiNt OS? NEOLOAD - Neo Desk? POWERDOS RESETNVR - Reset the NVR data? What is stored in the NVR? ROMSPEED SAM Silkmous - A mouse program? SLNTLINE SPDGDOS STFAXMGR TOS4_FIX WINX XBOOT - Xboot3 program I assume. Acc Menu ----------- AFM ALERT ANML1 ANML_82 ANML2 AUD_CD BLOWACC CCOLOR82 CLOCK - System clock in upper right corner? CLOCK2 CYBCTRL DESKPIC DRIVERS EDHAK EDITPLUS GEM_VIEW JPEG LDWCNVRT MOVIE NEOCNTRL NEOQUEUE OUTLINE RSMASH SAMCNFIG SCANLITE SNAPSHOT SOLITARE - The card game? STALKER TASKMAN - Task manager? TN_PCALC TRASHCAN WHATIS - Good Question! WOWBAGGR XCONTROL - Control Panel? ZCONTROL - Another Control Panel? CPX Menu ------------ ASCIITAB BCOLORS CALC CALENDAR CLIPBRD COLORVDI CONFIG COOKIES FALCONF FILEINFO FONTGDOS FORMAT FREEMEM FSM FSOUND GENERAL HDFREE_E - Hard drive free space indicator? HD_FREE IDT MACCEL MODEM MULTITOS NVRAM PRINTER SAM_SET SETENV SMC SOUND STFAXMGR - Fax Program I assume SUBMENU SYSTEM WCOLORS WINX SET Menu ----------- 1. 40-256 2. 40-TC 3. 80-16 4. 80-2 5. 80-256 6. Backwards 7. Chronos 8. Cybersculpt 9. Flash 2 10. GemView 11. Geneva 16 12. Geneva 2-80 13. Geneva 256 14. PageStream 15. Phoenix 16. Prism Paint 17. ST-High 18. ST-Low 19. ST-Med 20. Works NEWDESK.INF Box ---------------------- 80-256.INF ASSIGN.Sys Box ------------------- Nothing AutoStart Box ---------------- Nothing And there are a bunch of icons on the side of the screen. Can someone PLEASE tell me what half this stuff is? Tempest Quote Link to comment Share on other sites More sharing options...
krupkaj Posted January 31, 2004 Share Posted January 31, 2004 XBoot is boot selector. You can choose which auto start apps will start, which accessories will be loaded, which CPX will be activated. It is also possible to change config files (desktop, mint, ...) It is possible to make sets of all above Typically you need another combination of programs for MiNT and for Backward emulator. With XBoot is easy to maintain the start of the computer. I remember that I had little manual for XBoot, but I am not sure where it is. I try to find it. Quote Link to comment Share on other sites More sharing options...
[ProToS] Posted January 31, 2004 Share Posted January 31, 2004 PRG Menu ------------ BlowBoot - Boot sequence for the blowup device? I tried it with the blowup on and the monitor went wiggy. DESKPIC................................. for put a background img on the desktop EXTENDDOS - Extended Dos? ...................... extendos by anodyne software, cdrom driver http://www.anodynesoftware.com/ FOLDR600 ....................... put the folder limit of the to to 600 ( not needet if you use hddriver ) FPATCH1........................... not needed if you use fpatch2 FPATCH2 ................................This little patch fixes two problems in the Falcon BIOS (TOS 4.00-4.04) (1) Sound is not initialized properly. (2) Bconmap() doesn't work. GENEVA .............. geneva aes/os boot http://www4.pair.com/gribnif/geneva.htm JAR10............. extend the cookie jar to 10 ( come with geneva ) JAR30................ extend the cookie jar to 30 ( come with geneva ) JPEGD ............... Brainstorm dsp jpeg decoder MINTNP -MiNt OS? .................. mint kernel ( for geneva in your conf ) NEOLOAD - Neo Desk? ............... loader of neodesk ( with geneva in your conf I think ) POWERDOS ................... sort of multitasking shell RESETNVR - Reset the NVR data? What is stored in the NVR? ...................... for reset the nvrm, In nvram they have the conf of the language of the tos4.0* desctop and keyboard ROMSPEED ............................ work with winx patch... TOS speeder ... need gemram to put the tos in ram SAM .................... system audio manager , come on the f030 instal disks Silkmous - A mouse program? ................. mouse accelerator and screen saver SLNTLINE ..................................... ( unknow ) SPDGDOS ........................................ speedogdos STFAXMGR ................................... something for the fax app stfax TOS4_FIX .......................... another pacth for the tos4 ( unknow ) WINX .................... windows patch to GEM/AES with the tos in ram XBOOT - Xboot3 program I assume. .................. yes Acc Menu ----------- AFM .............. audio fun machine , comes with the f030 instal disk ALERT .................. acc for mint, put the alerts on a gem window ANML1 ........................... ( unknow ) ANML_82 .............................. ( unknow ) ANML2 ................................. ( unknow ) AUD_CD ......................... audio cd player BLOWACC ....................... acc for blowup CCOLOR82 ................. ( unknow ) CLOCK - System clock in upper right corner? ................. perhaps yes they have a lot of clocks CLOCK2 ................................... the same , just a clock CYBCTRL .......................................... seem's to be cybercontrol player for cyberstudio anims DESKPIC ................... acc for conf deskpic ( in the auto folder ) for put a background img on the gem desk DRIVERS ............................ for speedogdos EDHAK .............................. ( unknow ) EDITPLUS ................................. asii editor in acc GEM_VIEW ................................. multi forma mages viewer JPEG ........................... jpeg acc viewer ( work with jpeg.prg in the auto folder ) LDWCNVRT ......................... related to LDW Power Spreadsheet NEOCNTRL .................... for neodesk NEOQUEUE ................... for neodesk OUTLINE ....................... intall tool for speedogdos fonts RSMASH ........................... ? resourcemaster renamed as a acc ? SAMCNFIG .................... acc for conf sam ( auto folder ) SCANLITE ................................. ( unknow ) SNAPSHOT ............................... to made snapshots from the gemdesk SOLITARE - The card game? ................... a solitaire game ( I don(t know the english name ) STALKER ............................ terminal emulator acc TASKMAN - Task manager? ......................... yes for geneva TN_PCALC ................................. ( unknow ) TRASHCAN ............................. ( unknow ) WHATIS - Good Question! .............................. when you see one file with a unknow extension this app say "what is" this file WOWBAGGR ................................ ( unknow ) XCONTROL - Control Panel? ................. yes from atari to use *.cpx ZCONTROL - Another Control Panel? .......... yes, alternative to xcontrol to use cpx CPX Menu ..................... cpx's for use with x/zcontrol ------------ ASCIITAB .................. ascii table BCOLORS CALC .................... caculatrice CALENDAR .................. a calendar CLIPBRD ....................... clipbard tool COLORVDI ..................... conf the colors of the desk CONFIG COOKIES ................ see the cookies FALCONF ...................... some f030 conf FILEINFO ................ info for the selectect file FONTGDOS ...................... cpx for speedogdos FORMAT ....................... cpx to format a dd or hd floppy disk FREEMEM ...................... say the free memory FSM FSOUND ............... f030 sound conf GENERAL HDFREE_E - Hard drive free space indicator? ............. yes HD_FREE ..................... the same IDT MACCEL ................. mouse accelerator ( hummm they miss the maccel.prg in auto folder ) MODEM ................. to conf the serials ports MULTITOS ..................... cpx for multitos NVRAM .................. for conf the nvram ( tos language and keyboard ) PRINTER ...................... to set the printer for speedogdos SAM_SET ....................... for sam ( in auto folder ) SETENV ................... set environement ( dont remender what he do exactly ) SMC SOUND ................. another sound con ( to much sound cpx you have to remove some of them ) STFAXMGR - Fax Program I assume ............... yes for stfax SUBMENU SYSTEM ............... sysinfo cpx WCOLORS ..................... to set the colors of the gem windows WINX ............... cpx for conf winx ( auto folder SET Menu ........................ all of that are settings for xboot, when ou select one it put active what it was conf for that ( you can made your own conf ) ----------- 1. 40-256 2. 40-TC 3. 80-16 4. 80-2 5. 80-256 6. Backwards 7. Chronos 8. Cybersculpt 9. Flash 2 10. GemView 11. Geneva 16 12. Geneva 2-80 13. Geneva 256 14. PageStream 15. Phoenix 16. Prism Paint 17. ST-High 18. ST-Low 19. ST-Med 20. Works NEWDESK.INF Box ..................... it's for newdesk.inf files ( gem desktok conf ) ---------------------- 80-256.INF ASSIGN.Sys Box ................ its for speedgdos or nvdi conf files ------------------- Nothing AutoStart Box ...................... IIRC prg how start in auto folder all the time ---------------- Nothing I think it could give some help to understand Quote Link to comment Share on other sites More sharing options...
[ProToS] Posted January 31, 2004 Share Posted January 31, 2004 I forget some thing, you can have a look to the doc from the demo of xbot, it help you a lot to setup this app http://www4.pair.com/gribnif/files/Demos/xbootdem.zip Quote Link to comment Share on other sites More sharing options...
Tempest Posted January 31, 2004 Author Share Posted January 31, 2004 Thank you very much. Now I need to figure out which options I need. I have no idea which ones to use! Tempest Quote Link to comment Share on other sites More sharing options...
[ProToS] Posted January 31, 2004 Share Posted January 31, 2004 try every one and look with one you think usefull and after setup your own conf Quote Link to comment Share on other sites More sharing options...
