RockLobster Posted November 29, 2023 Share Posted November 29, 2023 1 hour ago, -^CrossBow^- said: So as long as you can get about 8v - 16v to that regulator it will do its job. Course the more voltage you give the regulator, the more it has to give off as heat. So the least amount you can give it to do the job with enough current, is the best overall. Thanks for the extra info including the other comment about other variations you've found to work. Just came back from a Goodwill trip and got a center positive adapter at 9V 1.5A and it took worked great. Can't beat $2, be smallish and lower voltage than higher! Now comes the hard decision... Should I keep my connected 7800 and Sears light sixer as my primary 2600 consoles or have this one replace the latter? Quote Link to comment Share on other sites More sharing options...
